Question about Kitchen Ranges
The top element is corroded and needs to be replaced. The clips holding the element in place need to be replaced as well. Can I do this myself? If so, how? If not, who should I call.
    President:
  • 497 Answers
If the element it self needed to be replaced and not the clips i would say okay and do it yourself, but the clips are tricky and its best to call a pro into do this. It will be worth the money spent to save the hassle of trying to replace without breaking. Depending on the manufacture, you could start there, otherwise any appliance tech can do this. Try Calling Sears.
Posted on Sep 30, 2009
if you look up above the heater you'll see a hole,you have to get a 5/16 inch socket and extention and there's a screw in there that holds a clip that holds the heater can in place on the top.it looks like this is the model you have.hope this helps.
May 16, 2013 | Dryers
How do you change the oven element on a Westinghouse PAJ143W as the element is hidden
To replace Westinghouse PAJ143W oven element you need to look at the back of oven with a torch etc, and you will see the element ends go into the back through clips on each side. At the top of these clips in the middle there is a bit where you get a screwdriver to push down and lever forward and it will come out a bit you do this on both sides. Then lift the clips and element 'both sides'' together and carefully pull forward making sure you're careful with the wiring and pull out a little making sure you stop the wires slipping back while you swap elements. Make sure you put plate at front back in place to keep element up off the bottom, it has two reswts for element on it.
May 20, 2012 | Sharp Ovens
I don't have a repair manual for White Westinghouse dryer. Need to replace heating element. Not sure how to get to the element
Instructions
    • Disconnect the power cord from the electrical outlet before servicing the Westinghouse dryer.
    • Insert the putty knife into the gap above the front panel and below the top panel. Lift the putty knife handle up to unfasten the internal locking clips.
    • Lift the top panel from the dryer cabinet. Rest the panel on the wall behind the dryer.
    • Remove the two screws on the top border of the front panel. Lift the front panel straight up to unhook it from the dryer cabinet. Unplug the connector leading into the front panel. Set the front panel aside.
    • Move the idler pulley arm toward the front of the dryer cabinet to loosen the belt. Remove the belt from the drum and pulleys.
    • Lift the drum out of the dryer cabinet.
    • Disconnect the electrical plugs leading into the heating element. Unfasten the screws securing the element to the inside of the cabinet. Lift the element out of the cabinet.
    • Place the new heating element inside the dryer. Connect the screws holding the element to the cabinet. Plug the electrical connectors into the element.
    • Reposition the front panel. Plug the door switch connector into its socket on the front panel. Press the panel straight down into the base. Reinstall the screws along the top of the panel.
    • Lower the top panel onto the dryer. Press down on the panel to lock it into place
May 12, 2011 | Dryers
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
The lower heating element on our Thermador oven arced and snapped in two. I'd like to replace it myself. Just wondering if the new heating element can just be snapped into place with minimum expertise,...
Most elements are very easy to remove and replace....there are a few clips holding them in place and a screw to hold the wire at each end of the element.
MAKE SURE to turn the power off before attempting the replacement...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 26, 2010 | Ovens
Can't remove top cover
HI There,
there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
I have written a detailed instruction on how to fix the turbine inside that controls the brushes. You may find this helpful:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you found this to be helpful, please be kind and leave some feedback for the repair. This is what keeps Fixya repair professionals like myself continue posting free repair instructions rather then using the premium answers that users pay to get answers. This is really greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Maytag electri single oven, not getting hot enough?
replace the lower element. easy fix. TURN OFF POWER. remove two screws inside that hold element in place. Pull forward. disconnect clips that connect wire to element. reverse steps to replace with new element.
Feb 28, 2009 | Maytag CWE4800A Electric Single Oven
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
Beko dwd5419w. My dishwasher wont heat the water, i have taken off the heater element and tested it and it works. what else should cause this problem
hi The heating element is used to help dry the dishes. In most dishwashers, the heating element fits around the screen in the bottom of the tub housing; it looks like an electric oven element. The heating element doesn't malfunction often, but it can burn out. If you suspect a faulty element:
Step 1: Test it with a VOM set to the RX1 scale. Remove the dishwasher's bottom access panel and disconnect one of the power leads to the element. Clip one probe of the VOM to each element terminal. If the meter reads between 15 and 30 ohms, the element is working. If the reading is higher than 30 ohms, the element is faulty and should be replaced.
Step 2: As needed, replace the heating element with a new one made for the dishwasher. Disconnect the electrical leads to the element's terminal screws and remove the nuts or other fasteners that hold the element to the terminals. From inside the tub, lift the element out. It may be held by clips and ceramic blocks in the tub, but you can easily thread it past these spacers. Set the new heating element in position, reconnect the power leads, and replace the fasteners that hold the element in place.,,,,,,,,,,,,please rate it
Nov 28, 2008 | Dishwashers
Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Aug 18, 2008 | LG LRE30451ST Electric Kitchen Range
Kitchen Ranges Logo
19 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
