Question about IBM Office Equipment & Supplies
Carriage only moves six spaces to the right and stops
  • Dick O Reilly May 11, 2010
    A model would be very helpful. DickyO
  • IBM Master
  • 3,594 Answers
If you have the L. margin all the way to the left the carrier may be catching on the L. black plastic dust cover they warp from motor heat Try pressing down on it while spacing if tou get pasy it move the L. margin over about 10 spaces and don't go past it or remove the L. dust cover.
DickyO
Posted on Oct 12, 2009
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
I recently bought a 1964 Hermes Ambassador typewriter. The typewriter is in very good shape, -but the carriage is slid all the to right (as if ready to start typing)and will not move. It acts as if it is...
I worked on typewriters for many years. If the unit has been sitting for years, it is in need of a good cleaning when you depress a key, it activate a mechanism that rotates a pawl on a toothed rack under The carriage. Plus there is a final stop that stops the carriage from going to far too the right. Flip the unit up and push the carriage lightly and watch the mechanisms spray light lube and keep moving the mechanism it should loosen up. Depress space bar and gently pull the carriage to the left. You may also have lost the tension cord. That's a spring assisted coil that pulls the carriage. You have an old unit there. It was great in it's time.
Feb 08, 2015 | Office Equipment & Supplies
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
When turned on it moves 4 spaces to the right stops and beeps constantly
Sounds like the multi-strand cable that comes out of the carriage assembly may have 1 or more broken wires... check and inch or two from the carriage itself.... if broken they can't be joined again( and work reliably)... the carriage unit would have to be replaced.
Feb 08, 2010 | Nakajima Office Equipment & Supplies
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
41 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
