Question about Microsoft Xbox 360 Wireless Controller
NEW XBOX 360 Controller Won't Connect Using Play and Charge Kit
I just bought a new XBOX 360 controller and it won't connect using the rechargeable battery pack (Play and Charge Kit), but when I put in double A batteries, it will connect. I have hit the sync button on the xbox and the controller and the 4 lights spin for a while, only to continue blinking and it is never found. So I have dedicated one controller to using just double A's and one controller using the Play and Charge Kit. It would be nice if I could solve the problem though.
2 Suggested Answers
fieldy14
  • 456 Answers
SOURCE: Xbox 360 controllers wont sync when using the
Opt out the easy way and put a rechargeable battery pack in the controller and use a plug and play controller cord to connect the console to the controller and , voila!, they should be now sync'd to each other.
I hope this helps. Good luck.
Posted on Sep 06, 2010
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Xbox 360 wireless controller won't connect to console
try getting a play and charge kit thats what i had to do
Nov 12, 2012 | Microsoft Xbox 360 Console
Xbox 360 controller won't stay on
just buy a plug in and play it cost about 10pound or 10 euro
Jun 21, 2012 | Microsoft Xbox 360 Controller
"HOW TO" use xbox 360 controller on pc games
Most games support the gamepad by default. You should not need any software or setup. But you might need the Drivers for it... Check this out, hope it helps:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming&type=Gaming&sku=JR9-00001
Mar 31, 2010 | Microsoft Xbox 360 Controller
Xbox controller problem
If you are using an hdmi cable make sure it is pushed firmly into the console and the tv. if you are not it may be a problem with the rf board, which is behind the on/off button. If you have, or can borrow a play and charge kit, the one that connects to the top of your controller, use this it usually works straight away.
Vote if this helps.
Jan 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 Controller Won't Connect To My 360....
You have to connect the controller like this: Somewhere on the XBox 360 controller there is a button that looks like this, o))) or something like that. Push that button and look at the XBox 360 round lights, they start to flash, that means you have to push the same button on the console. The o))) button should be infront of the console.
Regards,
Max
Jul 09, 2009 | Microsoft Video Game Consoles & Games
My controller wont turn on without the charger cord
If you are using a rechargeable battery and it hasn't been used for a year it is possible that it is not holding a charge anymore. You may have to buy a new rechargeable battery. A good way to test that there is nothing wrong with the controller is to throw some AA batteries in there to make sure. If the controller works fine with two AA batteries then you know that you most likely need new rechargeable batteries. If it doesn't work you have have a bigger problem with the controller or the cord, but I doubt that there is a problem with the controller.
Jun 26, 2009 | Microsoft Xbox 360 Controller
XBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Jun 30, 2008 | Microsoft Xbox 360 Wireless Controller
Xbox 360 controller stopped working
I have the issue mostly when the batteries are about to die, Try changing the batteries, or if you are using a play and charge kit (sold seprately) connect it to your xbox 360 and one of the front usb ports. Or replace the rechargeable battery.
Apr 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Wireless Controller Logo
501 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
