Question about Oreck XL Ultra Bagged Upright Vacuum
Vacuum keeps going off even after reseting reset button
  • 694 Answers
There's an obvious electrical problem. Examine the cord, especially near the plug. Check for kinks and blackened areas in it as well.
There's a good possibility of an electrical short in the vacuum itself.
I suggest taking it to a repair shop for testing.
Posted on Sep 30, 2009
3 Suggested Answers
advacak
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
SOURCE: reset button on riccar upright vacuum
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Posted on Dec 21, 2008
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Where is the reset button on a DC24 ball?
Hi there, it's Jack at Dyson.
In most cases, DC24's reset button should be located in a red recess on the side of the cleaner head, as shown in the video guide below. It may help to use something like the eraser-end of a pencil to press the button - you should feel a click as it engages.
Some newer DC24 variants don't include a physical reset button, and instead the reset mechanism will activate when you turn off the vacuum, then turn it back on and recline it into the normal vacuuming position.
If you can't see a reset button on either side of the cleaner head, this may be the case with your machine. If you're unable to reset the cleaner head, please contact our experts directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 14, 2015 | Dyson DC24 All Floors Upright Cleaner...
Hi my name is Sapphire. I have a dyson DC24. The roller bar keeps cutting out, I can't depress the reset button properly and so it won't start up again properly without me trying for ages. The brush bar...
One possibility is a failing reset button, Another option is a bind causing excessive energy to spin it. This will cause the reset button to trip. Check the bearings in the motor and brush roll.
Nov 09, 2014 | Vacuums
Reset button ON DC25I
Dyson created a good vacuum cleaner but it seems odd that this problem of sucking a shoelace would disable your vacuum cleaner. I even replaced the head. PLUS they want 150 dollars to fix. Come on, if this where Dyson is going, to create something that's going to cost 100's of dollars to fix, then DO NOT BUY DYSON! They did send me a new head but my head still won't turn even after resetting the electrical button. I BET it's an easy fix. Lucky all we have is hardwood floors but frankly it would be hard for me to suggest to someone else that Dyson is the best. A product is ONLY as good as the warranty behind the product.
Apr 25, 2013 | Dyson DC25 All Floors Bagless Upright...
Reset button Hoover
The majority of hoovers do not have reset buttons. Some vacuums that do, have one that only controls the brush roller when they are run by a separate motor. I would really need the machines model number to properly answer your question.
Although they do not have "reset" buttons, most do have thermal resets. If the vacuum motor overheats. Turn off, unplug and wait for 1 hour or more for the thermalfuse to "reset" itself. Also, clean or replace all bags/filters because that's usually the cause of overheat in the first place.
Also, vacuums go dead for a number of electrical reasons. Many of the Hoover uprights have an internal switch in the upper body below the handle that commonly fails and needs replaced.
Hope this helps.
Feb 20, 2012 | Hoover Vacuums
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Where is the reset button the riccar 8850?
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I think if it just stopped workint all or a sudden, it's prbably the reset switch.
If this was helpful to you, please help other Fixya users find the repair by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 09, 2010 | Riccar 8850 Vacuum
Where is the reset button located?
Greetings from GoVacuum,
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
Jan 15, 2010 | Riccar 8850 Vacuum
Reset button on riccar upright vacuum
Dec 21, 2008 | Riccar 8955 Upright Vacuum
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Oreck XL Ultra Bagged Upright Vacuum Logo
143 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
