Question about Sanyo DS25390 TV
Black screen white horizontal line help - Sanyo DS25390 TV
  • 647 Answers
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 30, 2009
Testimonial: "will try this my sanyo is model ds527510 You sent wrong person question to me please reply Black screen and bright white light in middle of screen"
    Genius:
  • 1,121 Answers
This a tipical Vertical Ic Problem, check also for deflector coil for deteriation
Posted on Oct 31, 2009
3 Suggested Answers
jomaru
  • 337 Answers
SOURCE: Picture went black
The good thing is you see something in the screen,with age the set has developed loose conections in a few different places,my suggesion is to call professional for service now and the repair will not as expensive,if the picture quality is good is worth it.
Posted on Sep 23, 2006
  • 20 Answers
SOURCE: One White Horizontal line on black screen
replace the vertical IC problem solved
Posted on Jul 09, 2009
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Black screen horizontal white line moving from top to bottom of screen
Hi Mandy
Think you have a problem with the cabel or if you could adjust the channel for the correct signal. Maybe the tv-chip on the consol are broken, and you live to far from me for me to help :)
you have any friend who could take a look ?
Best regards
Joakim
Feb 26, 2013 | Atari 2600 Console
Black and white horizontal lines in my asus a3000N laptop
Sound like the cable was lose between LCD panel and Motherboard. You can't do by yourself. Hope the laptop is still under warranty repair.
Nov 11, 2008 | Computers & Internet
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Televison & Video
Televison & Video Logo
760 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
