Question about HP LaserJet™ P2015X Printer
Have a HP Laserjet P2015X. Documents will not print unless we turn the printer off and then turn on again....then a few minutes later document will print. This was happening sparodically for a while, now with every print job submitted. We have a network setup with a server.....don't know if the problem is related strictly to the printer or could be a server/network problem.
  • HP Expert
  • 222 Answers
To be sure about your printer try to print something directly from any PC. If all is OK then ask your system administrator to check Network. if problem persist again use Web Jet admin to update printer firmware. WJA is a free HP software for network HP printers - very helpfull i think
Posted on Oct 01, 2009
I am using HP Laser Jet 1320 Printer i have a problem while printing as follows PCL XL error Sub System: Kernel Errror: Illegal Tag Operator: 0x1b Position: 6
This appears to be an issue with the driver.
Before replacing the driver though, make sure it isn't just the document itself that is the issue.
Try printing several different documents. If all other documents print, there's a problem with the document itself.
If several, or all documents from multiple sources (not all generated from the same program) then it's time to completely uninstall the driver, and then go to www.hp.com and get the driver specifically for your operating system for that printer and install it.
Remember to reboot between the uninstall and the reinstall.
If this yields the same results, then install an HP laserjet 4 driver on the same port as the currently installed driver using the add printer function in control panel/printers.
print the offending documents through this driver by selecting the HP Laserjet 4 as the printer when printing. If this solves the issue, make the laserjet4 the default driver.
Jun 04, 2011 | HP LaserJet 1320n Printer
I cannot get my documents to cancel for my HP laser jet CP1215 printer so the next one can print. It has been deleting for over 10 minutes
Turn off the printer
On your computer click start, click Run, and type in SERVICES.MSC
Scroll down in the services and right click "Print Spooler" and click "Restart"
This should clear out the spooled documents.
Please remember to rate my solution to show your appreciation!
Jun 01, 2011 | HP LaserJet CP1215 Color Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
While printing documents in Hp LaserJet 1020, along with the documents, another page with the details of the document is also being printed at the end. How do i solve this problem?? Please help me..
Simply uninstall your printer and reboot your computer. after reboot again install your printer.
If problem still not get rectified let me know i will give you another solution which is complex.
so do it first its simple
Jun 25, 2009 | HP LaserJet 1020 Printer
Paper light won't turn off
Tryloading paper in tray 1 / bypass assembly. Pull down the black tab under the HP logo
Feb 20, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
HP Laserjet 1020 reprints on logon
Turn off printer, Goto Control panel then printers and faxs, double click on your printers icon, a box opens with your pending prints, select file and cancel all documents, close all windows, restart printer
Dec 16, 2007 | HP LaserJet 1020 Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP LaserJet™ P2015X Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
