Question about Microwave Ovens
Re: Oyster Micro-wave 1000 watts-LED Panel not working correctly.
The LED Panel, when I input a 2 only part of it shows-in programming my clock-it skips the number I'm putting in and jumps to another #, thus
reflecting the incorrect time . It appears to reflect only part of some numbers.
Thanks,
A. Green
  • 574 Answers
You probably have to replace the keypad control, or you could try checking the connections to the keypad by taking the cabinet and checking the connections to see if they're loose.
Posted on Sep 30, 2009
Hi I am using kenwood microwave since last6 years.but now from last one year it suddenly started make sound while not in working and now it is not heating. Plz guide what to do
Time to throw it away. Microwave ovens can be dangerous if not working correctly. Micro-waves, (The actual waves themselves) can be lethal. Unless you really know what you are doing, do not under any circumstances dismantle the machine and switch it on. The cabinet of the machine is designed as a protective box and should stop random waves escaping and cooking anything else including you own insides. Generally Microwave ovens are uneconomical to repair, for the parts and labour you can buy a new one. Buy the most powerful you can. If you buy anything that is below 1000 Watts make sure it has a turn table. Remember that the more you place in a microwave oven, the longer it takes to cook. If you have a big family and you can afford it, you might like to think about a commercial oven 1600 - 1800 watts, that can cope well with large quantities well and will cook a tin of baked beans in less than a minute.
Rgs. Bob
Feb 21, 2016 | Kenwood Microwave Ovens
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave not heating water
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
How many micro wave ovens will a 20 amp circuit support?
Please stick with me to the end ... some examples are for example only. There is no 1000 watt circuit per'ci.
This will not be possible overload, this is an accident waiting to jump on you, my friend
Install dedicated circuits for these ovens, my friend. It will cost you a little but will be better than having dissatisfied guests or talking to the zoning board or boarding house authority or (gasp) the fire inspector after the fire.
If you don't do this, when the breakers start flipping off, tenants will run extension cords to outlets that have power. A whole different and worse, problem!
Rule of thumb, lighting circuits should be designed to operate at 80%, for example, if you have 800 watts of lights on a 1000 watt circuit, you are at the max.
So, there is a possibility that your circuit for lights is already near max. Adding ovens is trouble. Don't forget the iPOds and cell phone chargers as well as lap top chargers, walkman chargers (older students), little TV's, DVD players, clock radio's, electric shavers, curling irons, steamers, popcorn makers, lava lamps and occasional electric heaters that will be snuck into the room.
What is a 1000 watt circuit ... good question. Ohms law comes into play here.
Volts X Amps = Watts
120 volts X 8.333 amps = 500 watts (a smoothie blender) 300 watts (slow cooker) 200 watts (hand mixer) = 1000 watts.
A 15 amp circuit will protect #14 wire and can carry about 1800 watts (a toaster (1500 watts), for example).
A 20 amp circuit will protect #12 wire and can carry about 2400 watts (i am using a big paint brush here. these numbers are pretty close but not exact and I am not a licensed electrician.)
When I wire, I aim lots lower, preferring to OVER build than to under build.
10 amp circuits are rare in modern homes. In general practice, if the need was to be protected at 10 amps, the wire used in the circuit would be #14 and it would be protected by the breaker at 10 amps. In this case, it is the device plugged into this 10 amp circuit that needs protection rather than the #14 wire (which would be technically oversized)
Another consideration for you is where is the water? If you have an outlet that is 5 feet from a water source (bath - kitchen - etc) it must be protected by a GFIC
A 30 amp circut will protect #10 wire --- but this is not a normal household circuit.
Maybe the best option is for you to have your electrician install a sub panel in the vicinity of use and run several 20 amp circuits from that location to the various rooms.
The answer to your question "How many (1150 watt)micro wave ovens will a 20 (amp circuit handle)" is TWO with nothing else on the line. The National Code requires dedicated circuits for micro wave ovens, BTW. A commercial application may have a different (more stringent) standard in your town.
Thanks for the opportunity to answer your question and thanks for your interest in FixYa.com
Please vote - positive comments appreciated by volunteer question catchers.
thanks
a
Dec 12, 2009 | Maytag MMV4205 Microwave Oven
My micro wave stop working f-2 is on screen
Possibly a keypad short or motherboard fault if it is a KitchenAid microwave. Beware if you have a KHMS155LSS model, a Keypad short can and will cause the microwave oven to start on its own. A real stunning defect.
Sep 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Jul 11, 2009 | LG LTM9000 Microwave Oven
Kenmore Microwave Problem
"d" may mean demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
