How do I get to the fan relay in a Rheem REAB-1410 AC unit.
  • hatm23 Oct 01, 2009
    Thanks, but the top panel is where the coil is, it would be the bottom section where the fan is, the question is are there fasteners to be removed, or the shroud around the fan to be removed, or, or....
  • 358 Answers
The fan relay is located inside the air handler pulling out the top pannel.
Posted on Oct 01, 2009
Testimonial: "Thanks,actually in my unit there is a middle panel with the evaporator above and the fan and filter below. All the controls are in the middle panel."
  • christian nielsen Oct 03, 2009
    The relay is inside the wiring box you'll see when pulling out both pannels.
My fan will not turn off even if you shut system down
The fan relay is located in the air handler side of the system. Replace it and the fan will shut off normally.
Jan 16, 2016 | Rheem Packaged Gas And Electric Unit 13...
Rheem: REAB-1415J is not turning on. Replaced the fuses and breaker and still nothing. I even checked to see if the fan turned and it does freely.
check your capcitor it is a canister that wires pull into it is measured in uf 's it can also be checked by contiuity if you like my subgestion please give me a vote and rating
Sep 12, 2010 | Heating & Cooling
I have a Rheem Model # RAMB-030JAZ that the fan will not come on when the A/C is turned on and does not produce cold air. Is there a common electrical problem for this model that would prevent it from...
The unit has a fan relay that sometimes goes bad. Check to see of fan is hot or tryimg to start. Might be bad capacitor. Fan relay or relay boards are easy to change.Russ
Jul 30, 2009 | Heating & Cooling
The compressor on my home ac willnot kick on
The fan and the compressor both run off of the same circuit. Have your husband remove the cover on the condenser coils and check for power at the leads that go to the compressor off of the latching relay. If there is power there, then he needs to check the start capacitor or possibly the thermal overload switch (mounted on side of compressor)
Jul 11, 2009 | Heating & Cooling
My Rheem central A/C blower motor cycles on & off
Depending on age of Rheem they have a time delay relay. May be causing the problem. The time delay operates the fan. Try turning fan to continuous and see if it stays on.
Jun 07, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
I have a rheem air conditioner and the fan spins and it pushes air but the air is not cold enough?
hi! there,
well we have to do something about that,if you mention of fan spin and it pushes air but no cold enough on it,this refer to blower on compressor, there is fan on outside the condenser,so we are on blower w/c does not blow enough cold air,there are factors we can check,first thermostat try to adjust thermostat to the coldest point,
observed if cold was increasing if not, 2nd have clean the filter from evaporator it may have a clogged, check evaporator if there freezing ice on bottom portion of evaporator w/c cold was coming out,have it clean,cleaning this is done by certified a/c technician,there is problem if have an insufficient cold,this is the symptom of your system was under charge lack of freon,this can check by technician w/ clamp ammeter device.the operating current should be equal to rated current on manual,inform service center about this,have a nice day don't forget to rate me.thanks's
Apr 20, 2009 | Ruud UBHC Air Conditioner
Fan will not shut off, but compressor does
hi! there, continous fan motor when unit was shutt off,since supply source was already cut off specially on fan condenser motor,the supply of your motor was came from relay mounted on your circuit board control panel,there a holding coil to hold the connection between your fan and ac source,shut off breaker for ac unit first before diagnosing ac unit, try to check this out the relay is still activated giving ac source when shut off,the contactor on relay holding your ac supply was shorted,try to check the connection the circuit activating condenser fan relay,eliminate the short circuit,using multi tester test rod,use manual diagram for circuit control board to lessen complicated diagnosing,focus on fan relay ac source then isolate checking the short circuit replace defective relay,contact point of relay are not repairable.take necessary precaution on checking to avoid shock,this a hard task i would suggest that certified ac technician w/ full knowledge of instrumentation should do this.thank's for selecting fixya and have a nice day.
Mar 30, 2009 | Intertherm P3RA-036K Air Conditioner
I have a Rheem ac unit for a trailor. The wiring
Red goes to rc/rh
White to W
Green to G(fan)
Yellow to y
If a common it's usally blue or black
Mar 10, 2009 | Weather King 12AJA4801AH Air Conditioner
Rheem classic ix missing high pressure switch
Inhave a rheem ac the fan trunes and the slows down and stop how can I repalce this fan
May 24, 2008 | Heating & Cooling
Heating & Cooling Logo
491 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
