Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Does not focus to a clear picture.
The camera does not focus anymore. The lens comes out but it is more noise than before and does not focus. No error code.
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
My lens stopped working in Auto Focus mode. I can take a picture in manual but I can't seem to focus clearly. I prefer using auto focus for my everyday pictures, but the lens will not work. I am sure it...
there is couple of possibilities like wise when you zoom lens manualy and can you heard the hard noise then could be AF unit itself faulty. AF unit gear is gone.
could be AF shaft broken thats why not focusing
could be AF Flex broken thats why not focusing
for that please bring to canon service center
Aug 11, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Our camera was dropped this morning--now it reads Lens Error
oh no! you need to get the camera checked. there might be a lens that got dislocated inside the camera. Nikon is pretty fragile. Get it fixed asap or moist will damage the lens and it won't work anymore.
Sep 03, 2009 | Nikon COOLPIX S10 Digital Camera
Fuji a500 give "focus error" message and won't shoot pictures
I am sorry to say that this design of lens is the worst i've seen from Fuji.
Focus error relates to the mechanism right at the front of the lens. The motor and drive gear are in the end piece of the lens, as opposed to other cameras that have the focus mechanism in the back of the lens and is easily access able once inside the camera.
Does the lens stick? or buzz on power up? If you tap gently, with your finger nail, on the actual lens on power up ( you may have to do this several times) you may find the lens comes out ok and no error msg is displayed (until you try zooming).This will probably be because something is jamming the gears or the tiny tension spring used on the gears has come off. I have tried to clear several A500's with this problem with limited success.
Jun 23, 2009 | Fuji FinePix A500 Digital Camera
Focus error
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
May 27, 2009 | Fuji FinePix A500 Digital Camera
Nikon coolpix s710 focusing problem
the lens may be dirty. try replacing the batteries and taking an alcohol dipped q-tip to the lens.
Mar 15, 2009 | Nikon COOLPIX S710 Digital Camera
Camera will not take clear photos
As you have noted the lens is the root cause of this noise problem. I really believe there is grit in the lens gear thats preventing it from zooming or re-tracing. As for the blurring this can happen due to shutter lag.. a notorious problem in some of the powershot models. Either ways your camera needs service by an authorized professional. I would not advise you to try and clean the lens gear yourself as it can very easily get messed up and it would significantly rise the cost of the repair.
Good luck
Sai.
Feb 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
The focus lens was hit by a basketball and it won't take pics.
Have you tried a different lens on the camera almost any lens with the same mm size will work. If it still does not take pictures with another lens. You should take it in for service.
Dec 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
227 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
