Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for about 40 minutes and then the picture and sound went off again and the lights started flashing again. I unplugged the tv as it was unresponsive to the power off button. Please help.
  • 336 Answers
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Posted on Sep 30, 2009
When I turn the tv on it came on for a minute then started flashing on and off then went blank but the power light keep flashing off and on with a blank screen.
This problem is easy to repair. If when you turned the tv on and it had sound and picture for a second or two, and the power went off and the power green light keeps flashing on and off, it is a bad CCFL backlight lamp inside the LCD panel which has 10 of these lamps in it, but only one is bad. Replace the lamp and the tv will power on. What the tv is doing is, it has stored a lamp error code on the main board and turning the power off. The replacement lamp is part # RLMPLA029WJN1 and you can buy them at www.encompassparts.com for $19.49 ea. Go to their web sight and sign in as guess to order. I can give you step to step instruction on how to check how many lamps you will have to order if you need me, too. You will have to take the tv apart to check them.
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a Sony KP-53HS10 TV. The screen just died. There is a red light in the front that flashes, any idea on what to do? Thanks!!
this happened to us about 3 months ago. We were in the middle of a movie and the screen went black, red light flashing. we went online and the lamp bulb is blown. you can order a new on online, cheaper than Sony will charge you.
Apr 04, 2009 | Sony KP-53HS10 TV
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
238 people viewed this question
Henry  Thomas
Henry Thomas
