Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP Model number HLN437WX/XAA Last Night the screen went blank after the TV is on for 20 minutes The sound is fine The lamp is still lit, I can see that by looking around the back. I shut the TV off I removed the power cord from the wall and waited a few minutes and plugged it back in. The sound came on but the screen remained black, the TV shut itself off and the 3 led on the front were flashing
osborne382
  • 306 Answers
SOURCE: SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Posted on Nov 13, 2007
SOURCE: samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Posted on Apr 10, 2009
  • 304 Answers
SOURCE: samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Posted on Jul 17, 2009
tvtek
  • 1284 Answers
SOURCE: my samsung tv hlr5067wx/xaa screen turns black,
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Posted on Nov 19, 2009
  • 418 Answers
SOURCE: Samsung HLP5063WX/XAA 50
Bad color wheel.
Posted on May 02, 2010
Testimonial: "Diagnosis was on the money, ordered the color wheel on-line and installed it myself. TV is as good as new. Thanks!"
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
SMASUNG DLP 50 HDTV
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Hello I have a dlp samsung hlp4663wx/xaa. Last week the picture went black the sound is good . I replaced the lamp and the problem continues . I also replace the color wheel a year ago. know everything is...
It is the DMD board especially if the lamp stays lit. If the lamp is not lit... Be sure you have the lamp in properly...that is plugged in good and the door has the door switch engaged. Be sure door switch is still good and did not get damaged when replacing the lamp. DMD board can be found at encompassparts 1-800-638-3328 for 318.51 plus 150.00 for the core but right now is on FACTORY BACKORDER Part number
BP96-00678DCurrently on Ebay for 179.00 plus 15.00 shipping. Enter part number in search
Oct 24, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have a Samsung HLM617WX XAA DLP TV purchase in 2004. I replaced the lamp (BP96-00224J) in 8/09. Other than this the TV has operated perfectly. This week the screen went blank and the three LEDs flashed...
If the lamp is failing, the sensor on the ballast unit will shut it down. Check with a new lamp and ensure the cooling fans are clear and filters are clean.
Mar 31, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I got this tv (Samsung #hln437wx/xaa) used recently as is. I'm familiar with this type of tv as I own a Mitsubishi wd-52628. Problem:Before even powering-up the tv, I removed the lamp checking if it...
There is a power supply that supplies the circuit board plus the lamp, because of hi power there may need someone to look at the circuit board and maybe repair it
Should not cost that much
Aug 09, 2010 | Samsung HLN437W 43" Rear Projection HDTV
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
386 people viewed this question
Henry  Thomas
Henry Thomas
