Question about Sharp Office Equipment & Supplies
Model EL-6061A Replaced battery, pushed Reset, and now "Reset OK?" is flashing. How do I confirm OK and get to work again?
2 Suggested Answers
SOURCE: i inserted a new battery to Sharp EL 6092 ,it tell
First press the reset button then when the display says "RESET OK ?" press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter. Display will then say "BUSY". Reset is then complete.
Posted on May 28, 2011
Sharp el 6710s
im still trying to figure out why my hp 4620 doesn't print or copy
Jan 24, 2014 | Office Equipment & Supplies
GE gld5708vbb flashing lights locked controls
It is possible that since the neutral was bad it could have made a surge on the power and caused the processor controller to fail. It is also important that this must be confirmed to be corrected by checking with a larger load like a heater being switched on and not causing any voltage drop. If so the line is clear. Also make sure that the ground - Earth- is also intact.
The program has reset because of an error and it must be confirmed to be within or outside the washer. So remove plug and test this terminal with a large load test to confirm that the outlet is OK.
If so check the panel connections or is best to refer back to the dealer as the replaced panel will have a warranty.
Please take second opinion before the board is removed.
Jun 28, 2012 | GE 24 In. Black Built-In Dishwasher -...
I have a UPS Smart 5000va model :surtd5000xli I replaced all new battery for ups but when i started ups all leds in the battery column litting .I want to connect ups and pc to reset new battery (this ups...
Unplug your UPS from the wall. Disconnect the batteries. Push the on button. LED's may flash. This is how to reset the logic. Connect the batteries and plug back in. Everything should be reset.
Aug 03, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I inserted a new battery to Sharp EL 6092 ,it tell me Data problem,please reset.After reset tell me reset ok?Then i press any button it tell me again Data problem. I dont understand
Feb 21, 2011 | Sharp Office Equipment & Supplies
I recently bought a nuvi 680 from ebay and turned it on, seemed to work ok except that the bluetooth firmward was absent. I found and updated the firmware...worked ok....then decided to update the map...
When you install a new map, you need a new unlock code. Do you have a file named "gmapprom.unl" within the Garmin directory on your Nuvi?
- Jim
SHARCNET-USA
Apr 15, 2010 | Garmin Nuvi 660 GPS Receiver
How do I replace the photoconductor where is the menu button to reset PC CNT appears after it is replaced?
Power the printer on and get it to the Ready state. With the printer on and in the Ready state, open the front cover.
Press and hold the Cancel button until all of the lights begin flashing up and down.
Release the Cancel button and close the door. The photoconductor count should now be reset.
To confirm that the photoconductor page count has been reset, it is recommended that you print a menu settings page and check the photoconductor level. Do the following:
With the printer at the Ready status, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Look for a section labeled Cartridge Information and locate the word Photoconductor under this heading.
Confirm that the photoconductor level reading is either OK or close to 100%.
If the reading is low, try printing 10 - 20 pages. Print the menu settings page(s) again.
Confirm that the photoconductor level reading is OK or close to 100%.
Good luck, Gerrit Jan
Oct 29, 2009 | Lexmark E232 Laser Printer
No setting instructions.
Atomic clocks are the wave of the future because of their precision. While it takes a scientist to fully understand how these clocks actually work, the general public is primarily interested in their accuracy, rather than their construction. A major benefit to atomic clocks is that they serve as the main standard for calculating time internationally. While each version of atomic clock may have minor differences, for the most part, they are set in the same way.
1. Remove the battery cover on the back of the clock using the correct screwdriver (if one is required). Be careful not to break the cover or lose any screws in the process. Insert the required number and type of batteries into the clock. Most atomic clocks take two AA batteries. Make sure the batteries are positioned with the right polarity in place, and that the clock is functioning, before replacing the battery cover. Place the cover back into its original position and screw any necessary pieces back into place to secure the cover and protect the batteries from springing free.
2. Enter the program mode of the clock by holding down the appropriate button. In most cases, the button will be clearly marked "Set." If not, refer to the clock's instructions to find out which button fulfills that function.
3. Push the button down until the clock flashes its default time zone setting of --5EST. It is now ready to program each function separately as described in the steps below. If for some reason the clock does not respond as outlined, refer to the instructions provided with it for troubleshooting guidance.
4. Press the + button to select the right time zone from the 13 international options provided. The default setting of --5EST (Eastern Time), should appear first, followed by --6 CST (Central Time), -7MST (Mountain Time), -8PST (Pacific Time), -9ALA (Alaskan Time), -10HAW (Hawaiian Time), -11, -12, GMT (Greenwich Mean Time), -1, -2, -3 and --4ATL (Atlantic Time). Then push the "Set" button down again to confirm the time-zone setting you have chosen. Push down the "Set" button again and hold until the selected time zone flashes.
5. Press the "Set" button down two more times to establish the default language setting. Press the + button down to select English, French or Spanish. Then push the "Set" button down again to confirm the language setting.
6. Push down the "Set" button again and hold it until the time zone flashes. Then press the button down three more times until the time 12:00 flashes. Press the + button down to select the hour at the time of the clock's setting. Make sure the hour is set appropriately to AM or PM. Then push the "Set" button down once more to confirm the hour setting.
7. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button four more times until 00 flashes. Press the + button down again to select the minutes at the moment of setting. Push the "Set" button once more to confirm the minute setting.
8. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button five more times until the default year flashes. Press the + button down. Toggle through the settings until the appropriate year is reached. Then press the "Set" button down to confirm the year.
9. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button six more times until the default month of January is reached. Toggle through until you reach the right month. Then press the "Set" button down to confirm the month.
10. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button seven more times until the default date of 1 is reached. Toggle through until you reach the right date. Then press the "Set" button down to confirm the date.
11. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button eight more times until the default setting of Sunday is found. Toggle through until you reach the right weekday. Then press the "Set" button down to confirm the weekday.
Hope this helps......best wishes.
Aug 28, 2009 | GPS
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
Some radios hold the codes for a few Min's.However ,Disconnect the battery again and leave disconnected for an hour.Then reconnect and Enter codes and confirm.Should work ok.
May 29, 2009 | 2000 Renault 181
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
