Kenmore 24032 \ 24036 Top Load Washer
Oasis elite top load washer
shared by 2 users
posted by teepeegirl on Dec 19, 2007
when it starts to rinse the screen flashes lf
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by mgschicago on Jan 04, 2008
Have the same problem. Any solutions?
Best Solution
posted on Jan 23, 2008
FixYa! (100)
Master_Tech
Rank:Guru Guru
Rating: 88%, 653 votes
LF code LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display
You will need to check you fill hoses this is 95% of the problem in the rear of the unit ther are two hoses Hot and Cold feeds shut off the water and Unplug the unit Then remove the hoses from the machine. in the Valve where the hoses go to there are little mesh screens they are most likely clogged take a eyeglass screwdriver or paper clip and hook the screens pull them out carefully and clean them reinstall and connect hose and test
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on oasis elite top load washer:
I don't want to Accept this solution
Best Solution
posted on Jul 23, 2008
Helpful (85)
dioalp
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
We have also encountered the problem and pressing cancel and restarting the wash cycle has always resolved the problem. Now that I read your post/response I've given more thought and believe the problem is a reflection of our water system. We are on a private well and when the charcoal filter is nearing replacement (evidenced by slow water flow) together with lower pump pressure the right condition is introduced throw an "LF" error code. While I haven't proved/tested this, I believe if I were to change out the filter, the problem would be eliminated.
Most residential home neither have whole house filters or private wells and rely on the water supplier for proper pressure. The water district however seldom offer consistent pressures and a drop in the pressure could certainly reduce water flow, triggering the "LF" code.
Thank You!
Can you Help with these Washing Machines problems?
I have a kenmore washer,top load about 14 yrs. old....
i tryed i just need help putting it on
In the spin mode, I can rather easily stop the drum. This...
Does fine until the spin cycle. Agitator spins, but tub...
Machine stopped in the middle of a load. It is full of...
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
