Can,t install my Brother MFC-465CN allin one printer.I have windows xp. It shows being installed in "printers & Faxes but doesn,t print or fax or scan. Fax or scan is not shown as being installed. Harold Hooper hooper_h@bellsouth.net
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
You need to check if you have a valid printer driver and make sure you have no pending docs
Posted on Sep 30, 2009
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
I can not clear the memory MC-465CN on the fax - this is a mulitple function Brother - copies, scans, faxes,photo
If you clear the memory, any faxes stored will be also be erased. This solution assumes that you have the fax storage option "On" to store faxes in memory.
On the control panel:
1) Press <Menu>
2) Use <Up> or <Down> arrow keys until "Fax" appears on the display, press <OK>
3) Use <Up> or <Down> until "Remote Fax Option" or "Advanced Fax Operation" appears, press <OK>
4) Use <Up> or <Down> until "Off" appears, then press <OK>
5) You will be prompted: "Erase all fax?" 1. Yes 2. No
Press <1> to erase all faxes in memory.
6) Press <Stop/Exit> to return to normal function
Jan 29, 2010 | Brother MFC-465CN InkJet Printer
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
I cannot get my fax to work. I recently changed computers. It prints fine
Sounds like your new computer is not recognizing the fax.
Go to: start>controlpanel>printers/faxes
There you will see an option to add a fax printer.
Add your fax there.
If your fax is not listed as an option to add, the drivers for it with need to be downloaded of the installation disk.
If you have no disc, the drivers can be obtained through the Brother web page as per below:
For additional assistance, consult both the Help program in your computer of the start button again, and your fax manual.
Should you have no manual, check this site for a downlodable manual for your fax, or visit the Brother home page for links to support/troubleshooting and customer service.
Oct 06, 2009 | Brother MFC-465CN InkJet Printer
It will not print from the pc,[in printers and faxes it shows that it is off line and is in gray]. Have tried to change setting, but it still reverts to off line.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also because you mention it goes off-line frequently.
Sep 17, 2009 | Brother MFC-465CN InkJet Printer
Memory full
Here is the user's guide.
Go to page 65 (page 81 on the reader bar on the bottom) and turn off Advanced Fax Operations > It will ask you if you want to print the faxes or erase them. Also, see page 80 ( page 96 in the reader) first. It explains what to do.
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 15, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
Dec 08, 2008 | Brother MFC-210 All-In-1 Print/...
Brother MFC-465CN wont print
I had a similar problem, and it was due to the IP address not being properly set during installation. (Note, I installed it as a network printer. If you installed it as a USB printer, this won't work) Try this:
Select Start->Printers & Faxes, a window comes up, hopefully your Brother printer is one of the printers.
Right-click on the printer icon and select properties
Select the "Port" tab in the window that comes up
One of the entries should say "Standard TCP/IP Port". Click on that entry and click the "Configure Port..." button, a window will come up.
In the "Printer name or IP address" field, you may have a name here instead of an IP address. (Mine was "BRN008077E21669") Change this to the IP address for your printer. You can get this by navigating the menu on the printer (Under LAN->TCP/IP). I changed mine to 192.168.1.80, since that's the address I configured my printer for.
Hit OK and Apply in the open windows and hopefully you wil be in business. Good Luck!
Sep 09, 2008 | Brother MFC-465CN InkJet Printer
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
