Question about Samsung Refrigerators
Noise from fan on american samsung freezer resulting in water dispencer beside ice dispencer not getting water out but ice dispencer still workingwater dispencer stopped for weeks then the water dispencer just worked for 2days itself now gone again.
  • 142 Answers
Sounds like fridge evaporator has over iced and then frozen the water chamber below it might just need a 48 hr defrost with doors open.
Posted on Sep 30, 2009
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an american style fridge freezer from Samsung and it is buzzing when the fridge door is shut. I am guessing there is an ice build up around the fan but cant get the cover off easily. Any ideas...
i had a fan noise and the repair tech replaced the fan...turns out that the new fan was also making noise which lead me to look for other problems which lead to the fan problem
new fan was also buzzing in my freezer after some time...noticed ice build up towards the bottom right corner of the back panel (in freezer)....i diconnected power...took the back panel off .....fan had frost on it....coil was iced up.... then on the back of the refrigerator i accessed the control board....plugged the power back on ...i jumped the line to the heater...heater didnt work....then checked resistance through the heater (checked ok)....
it came down to me replacing the defrost thermostat which is in series with the heater....defrost now works fine ...which is every 60hrs for 45 minutes on mine.
good luck
Oct 02, 2009 | Samsung Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Water accumulating in bottom of freezer
The water was not coming from the dispenser or the ice maker. It is a result of a plugged defrost drain tube.
When the refrigerator goes into defrost, if the water is unable to get out the defrost drain, it ends up on the floor of the freezer. You will have to clear out the defrost drain. It is a tube which is behind the back wall of the freezer compartment, at the very bottom of the cooling coils. Use a turkey baster with hot (not boiling) water to flush it out until the water runs out the drain (and into the defrost drain pan under the refrigerator where it will evaporate as the fan blows air over it).
Dec 10, 2008 | Frigidaire Refrigerators
Samsung american fridge freezer ice tray is stuck at angle and wont make new ice
I had the same problem, It's because you have tried to press the button with the door open to get the tray to rotate. If your pressing the overide button with the door open you need to pretend the door is shut by pressing the hinge thing (it's half way down the left hand side of the freezer, turns the light out aswell) or else it the tray tries to do a 360 whitch it can't. You have to force it back to central. I can get mine to work and water is coming out of the water shute but no water is going into my ice tray to make the ice. I put some normal ice in and it dispences ok but it just wont make it's own. Anyone got any ideas ?
Oct 25, 2008 | Refrigerators
Fridge Freezer issue
If it is a HMMMMM...CLICK sound it is the relays. (approx. every 30sec or so).... OR, condensor fan located next to the compressor.... Otherwise it is more than likely the fan(evap Fan)!
Goodluck,
Brian
Jul 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
