Question about Proform 530 Treadmill Walking Belt
My treadmill belt is flipped over.
I attempted to adjust the belt because it was off center by rotating the hex screws at the base on each side. That resulted in a worse problem, now the belt has flipped over half way. How doI fix it?
maxtreadmill
  • 832 Answers
SOURCE: I adjusted the belt so it would be more centered
Under your motor hood you have a drive belt that can also slip. Depending on make you may after loosening the motor bolts and have an adjusting bolts.
Posted on Feb 28, 2010
  • 12 Answers
SOURCE: belt speed fluctuation
I assuming these hex screws are near the rear of the unit. But they should not affect operation unless really out of whack, but they should be adjusted with the belt moving. Try manually moving the belt first.
If it moves and If it is a newer machine more than likely the motor sensor is telling the control board that the motor is not working and it is shutting down as a safety measure.
If it doesn't move - somethings jammed
Posted on Mar 13, 2009
  • 19 Answers
SOURCE: proform treadmill belt won't stay centered.
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
Posted on Apr 28, 2009
  • 3 Answers
SOURCE: HOW DO YOU ADJUST THE BELT ON A PROFORM 725 SPACE
Use the allen wrench to loosen side that is touching. 1st locate on the end of the treadmill 2 slots, 1 on each side and place the allen wrench into the slot. turn anticlock wise 1/4 turn. Turn on treadmill at 3 to 4 miles per hour (not standing on it) and make ajustments in 1/4 turns until belt gets centered and snug. When you have it centered you may ahve to tighten or loosen it in case it is slipping when you are running on it. When you ajust it when centered you should do this in 1/4 turns on both sides to keep it centered. If this doesnt fix the problem I suggest that you may have some other problem or are not capable of reolving this problem on your own. Ask another friend for there opinion if this fails.
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a Proform 380 Treadmill. When the treadmill
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Posted on May 24, 2010
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
The belt on my proform 680LT has an excessive amount of rubber powder rubbing/shedding off. It makes a mess.
Is it rubbing off the sides of the belt? If so, adjust the lateral movement of the belt with the hex bolts at the base of the treadmill. If not, you may need a new belt. See Treadmill Parts
May 03, 2011 | Proform 680 LT Treadmill
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
I have the Incline Trainer X7i. i lost the manual. the belt is tracking to the left and rubbing the side. how do i adjust the tracking to get it back to center?\r\nthank you,
Find the allen key that came with the treadmill. It is used to assemble and adjust the treadmill.
Locate the 2 adjustment screws at the rear of the machine. If the belt is shifting to the left, tighten the left screw (turn clockwise) and the same if the belt goes to the right, tighten the right.
Only turn the screw 1/2 turn and move the belt manually to shift the belt. If it requires more, turn another 1/4 turn, very little adjustment may be required to straighten the belt. Once the belt stops rubbing, start the machine running slowly (1-2 mph) and observe the belt FROM DIRECTLY BEHIND THE MACHINE. Carefully adjust the rear roller till the belt is as close to center as possible making small adjustments, 1/8-1/4 turn clockwise of the adjustment screws.
Dec 15, 2010 | Nordic Track Exercise & Fitness
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Walking belt on image 10.0 tread mill slips, purchased it used, can see where it has rubbed to the left. How to adjust it?
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Feb 25, 2010 | Exercise & Fitness
How do you track a belt on a reebok vista treadmill?
There are 2 allen screws on the rear of the machine. Use an allen wrench and access the side in which the walk belt is tracking towards. (tracking to the right go to the right screw) Insert the allen wrench and rotate the screw one revolution CLOCKWISE. This should move the belt 1/4 inch towards the center. If needed you may rotate the screw one and possibly 2 more revolutions but more than that you may have another issue with the machine.
Good luck! Tim
Nov 24, 2009 | Reebok Vista Treadmill - RBTL13305
I have problem with my Proform 575. The motor rotates but the runner does not turn. There is a squeaky noise. Solution please.
It sounds like the belt is slack there should be an adjustment at the rear of the belt at either side of the treadmill usually a hex stud or allen key, if that doesn't help check the drive belt that comes directly from the motor which could also be slack or damaged.
Oct 18, 2009 | Proform 575 Crosstrainer Treadmill
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Jul 14, 2009 | Exercise & Fitness
Proform 530 Treadmill Walking Belt Logo
462 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
