Question about Canon Pixma MP500 All-In-One InkJet Printer
Says ink cover is open and it isn't - Canon Pixma MP500 All-In-One InkJet Printer
    Guru:
  • 389 Answers
Lid has a salient, which presses on sensor, check its work, he must нажмать on button
Posted on Sep 30, 2009
  • Sergey Artuganov
    Sergey Artuganov Sep 30, 2009
    Lid has a salient, which presses on sensor, check its work, he must push on button
Why my printer always said cover is open and close ink cover but the ink cover is close and the ink is full?
Hi, Try taking out all cartridges, unplug the printer a few minutes.
re plug , turn on. with ink cover open. then close cover and wait to follow the install prompts, This should reset the printer.
be sure to gently push the cartridges till each one clicks.Close cover.
Please let me know if this helps!
Feb 19, 2015 | Brother MFC 420CN All-In-One InkJet...
Why is a light flashing for color ink cartridge?
Usually that means you are out of ink for one of your color cartridges. If you just replaced your color cartridges with fresh ink then it could be that one of the cartridges isn't seated properly. You might want to open it up and check it out and re-seat your color cartridges.
May 21, 2012 | HP Deskjet D4300 series
Printer brand brother model DCP-J125. does not working properly, Close ink cover has appear the LCD monitor
The sensor for this is actually used for both the scanner cover and the ink cover,
there are two flags that both must sit into the sensor to reach a ready state.
If you examine the ink cover there's a small piece of plastic that paths into a hole on the machines frame. This piece of plastic pushes a small black plastic flag that tells the sensor the door is closed.
If it's constantly telling you to close the ink cover inspect both the cover itself to verify that piece of plastic isn't broken and is going into the hole; and look inside and verify the flag isn't broken or damaged (flashlight and a small eyeglass screwdriver help here)
Either can be fixed for cheap at any reputable printer repair shop, I would look for a brother warranty place even if it's out of warranty as they'll be more likely to have donor machines sitting around for spare parts.
Jun 01, 2011 | Brother Office Equipment & Supplies
My lexmark Z2300 will not feed the paper. The roller in the back (by the paper) does not move. I just changed the black ink. It has also said communication problem when I tried to print. NOW when you...
Disconnect the printer from your pc. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check the cartridge area and make sure there are no obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip) behind the carrier. If everything looks fine, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Close the cover. Reconnect printer to the computer. Try to print again.
May 24, 2011 | Lexmark Z2300 InkJet Printer
My Canon ip3600 has full ink, there is paper in the tray. It will print the page I want it to print. However, there isn't any ink / text on the pages that are being printed
It sounds like either the ink cartridges are clogged, or if you've installed new ones, it could be you forgot to remove the tape that covers the ink jet on them. If clogged, you can use alcohol on a Q-Tip to clean the jets.
May 06, 2011 | Canon PIXMA iP3600 Photo Printer
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon Pixma MP500 All-In-One InkJet Printer Logo
44 people viewed this question
old marine
old marine
