Question about Vostok Watches
Vostok Amfibia Black Sea Automatic Watch has stopped working.
I have a Vostok Amfibia Black Sea Automatic Watch. The watch is approx. 18 months old and has stopped working. If I set the time it runs for an hour or two and then stops. I have tried moving my wrist etc. which seems to keep it running for a while but then it just stops. The watch has worked fine since I bought it albeit sometimes running a little fast. Can anyone help?
  • 14 Answers
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
bikie,
It would be easier to tell you more if the age of the watch was posted, but not knowing that I am going to assume it is less then 3 yrs old and in good shape. He goofed! Never be afraid of asking someones experience level when working on something that belongs to you, find out if they are just a clerk in a jewelry store and are getting paid minimum wage and care more about their paycheck then your watch, OR if they have been doing it forever and care if you come back again! "IF" the watch is older then I assumed, or in questionable condition (a few bumps and scratches) then it may have nothing to do with the fact that the battery was just replaced, it really could be it's "time" to expire, pardon the pun!
Posted on Dec 01, 2007
SOURCE: tessot steel wrist watch band
i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
Posted on Jul 13, 2008
VOTIT
  • 2071 Answers
SOURCE: How to remove the Crown
the video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now is pushing, while pushing you pull the crown .That's why ill tell in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click fixya .It is the only way i get paid for my works also,please consider leaving feedback..
Posted on Jul 16, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: watch goes slow when wearing
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Posted on Jan 07, 2009
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
MY K3 WATCH HAS STARTED TO STOP AFTER ABOUT A MINUTE AND NEEDS A SHAKE TO START IT AGAIN do you know where to contact for repairs in the uk
Since your watch is an automatic type, it will stop if it is not worn.
Shake it gently side to side for a few minutes to fully wind it up and it should work for a day or two.
This type of watch needs to be worn daily to keep it wound up.
If you still have problems, then try following this link to the UK dealer http://www.sovietwatches.co.uk/index.php?app=gbu0&ns=contact&sid=cz3i7cljnk4r1os1207uy2xqk5gz839r
Oct 27, 2010 | Vostok Europe "K 3 Submarine" Blue Dial /...
Hi this is riaz from dubai I am looking continetal automatic watch here let me know how can I have here
mcdevito75 Here Hello riaz, ebay is your best bet to find your watch. Type in ebay on your computers home page and search under watches, jewelery on ebay.
Jun 12, 2010 | Vostok ''Continental'' titanium automatic...
I need spare part for my k3 submarine watch: I need Screw Down Case Pipe + Crown. Where can I find it in Australia?
Assuming that these parts are unique to your make of watch, then according to their web site there are no distributors in Austrailia.
If you go to their web site (www.vostok-europe.com/), you will see a map of the world and the countries that have distributors are shown in red.
Your nearest distributor is in Indonisia but you could just a easily order one from an English speaking country (to increase the chances of getting what you want!)
Feb 02, 2010 | Vostok Europe "K3 Submarine" Black Dial...
Fault with a Vostok Europe Red Square watch
The crown holds in place by one little screw inside of the watch. It is a very easy fix - you just need too open the watch and tighten the screw.
Or even better solution - send it back for repair. All Vostok-Europe watches are covered by 24 months warranty.
W-Precision
Sep 02, 2009 | Vostok Watches
Butterfly clasp on vostok watch
sadly there is no warranty that lasts 9 years . try any good local jewelry shop many do repairs .at least here in the US they do
Nov 13, 2017 | Vostok Europe "Pobeda" Watch
Automatic watch not working
I would suggest you do the following........
Pull the bezel out to the first notch then wind the it back and forth for a couple of minutes then that should be it.
How do i know this. I have had a Roadster for a 6 years and just found this out yesterday.
Enjoy the watch.
rgds
Feb 15, 2009 | Cartier Roadster W62016V3 Wrist Watch
Vostok N1 watch
In the 2nd position of the stem rotate the hands between 8 and 12 and the date will change.
Sep 26, 2008 | Vostok Europe "Rocket N 1" Black Dial with...
Watches Logo
364 people viewed this question
Top Vostok Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Vostok Watch Expert? Answer questions, earn points and help others
