Question about GE Refrigerators
GE Hotpoint Refrigerator CSX25GR CSX22GR CST 25GR frozen coils
I have a GE Hotpoint Refrigerator CSX25GR CSX22GR CST 25GR. The refrigerator area is running about 60 degrees at the top. Thermostats are turned all the way up. Freezer is cold, but not freezing. Back of the freezer is covered with frost, which I'm told is the coils and they need to thaw. I've cleaned thoroughly under and behind the appliance. As far as I can tell, the motor/compressor (?) are running constantly. I've heard the cause of the frost could be the defrost timer, heater or thermostat. I don't have anything to test these to see if they function, and don't know how. So now what? Do I replace one and see what happens next? Help!
SOURCE: Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Posted on Aug 23, 2008
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
  • 44 Answers
SOURCE: My hotpoint refrid. (Model CSX25GR) keeps leaking
Sounds like a plugged drain tray under the coil. It needs to be unplugged for 24-36 hrs to melt all the ice and then remove the panel covering the coil to see why it's blocked. Sometimes they just need to be blown out to clear it.
Posted on Aug 31, 2009
  • 454 Answers
SOURCE: hotpoint CSX22GR water/icemaker connection
You should be able to buy a generic water hose at your local hardware store.
Posted on Oct 04, 2009
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
HSS25GFP Neither side will cool down inside. Both sides set on 9
Hi... I don't know this particular machine... but I'll assume there are 2 separate thermostats as the temps are different. The purpose of the fan is simply to circulate cold air... It doesn't matter if there is one or two compressors as a fault is affecting both sides... I would say motherboard/supply problem.
Feb 14, 2014 | Hotpoint Refrigerators
Hot on top, cold on the bottom on both sides
Mine did the same thing and the circuit board that controls the fans had gone bad . It could be that or the fan itself.
Jun 06, 2012 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE GSS25QGTABB side by side. Despite the digital thermometer being set at 0 degrees (freezer) & 37 (fridge), my freezer does not go below 11 degrees, and the fridge at 48 degrees. Compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 26, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE Hotpoint Top-Freezer model - freezer works but the rest of the refrigerator is not cold - even when we turn the cold dial up to 9. Model - CTX14C1TGLWH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 01, 2010 | GE Hotpoint Top-Freezer Refrigerator
GE Profile PFSF5NJW French door Bottom freezer. Freezer is fine. Refrigerator at 60 degrees. Unplugged for two days to thaw any possible freeze up. Refrige still at 60 degrees.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Nov 21, 2009 | GE Profile PFSF5NFW Bottom Freezer French...
Hotpoint CSX22GR water/icemaker connection
Oct 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
735 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
