Question about Casio Exilim EX-S880 Digital Camera
Lens comes out makes a strange noise and goes back in
When I turn my camera on, the lens comes out makes a weird noise goes back in, my camera then turns itself back off again
silly girl
  • 513 Answers
SOURCE: Lens Error
first of all the manual is available on this site, in case you'll need it in the future. the manual says that if you have a "lense error" message it means the lense is obstructed, i'm guessing against it in your case, but its worth while checking to see if theres nothing jammed in its track. it's actually a known, and common problem with these small casios. i heard that a quick fix is that when it happens the camera battery has to be removed, and that should clear it, but the problem can also return, and after a while that trick won't do the trick any more. if you want to have it fixed while still in warranty don't wait to see if any of the common "blow air into the..." or "use some epoxy" fixes help you, you can try all that later. good luck
Posted on Feb 06, 2006
t00nz
  • 4738 Answers
SOURCE: My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 10, 2009
pauman
  • 248 Answers
SOURCE: casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Posted on Jul 05, 2009
VinayT
  • 1884 Answers
SOURCE: When I press the on button, the lens comes out,
May be some dust particles have gone in the lens well between the body and the lens casing. Try to **** it out with the vacuum cleaner.
Posted on Aug 08, 2009
  • 102366 Answers
SOURCE: lens error with Casio Exilim EX-Z80 and makes a weird buxxing sound please I need help
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
Jul 13, 2010 | Casio EXILIM 10.1-Megapixel Digital Camera...
Lens making strange clicking noise when turned on or zoomed in.
If the noise wasn't there for 3 days and is there now, it can only get worse. I would return it for a replacement.
Apr 27, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hi when i switch the camera on the shutter comes out ,a strange clicking noise and the shutter goes back in ,it is only 4mths old .
Hi there its a problem of your camera lens guide pin. Which is operate your lens for focusing. Thats pin is damaged & thats why shutter comes out ,a strange clicking noise and the shutter goes back in . Thanks.
Mar 25, 2010 | Kodak EasyShare M420 Digital Camera
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Jan 05, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
