Question about Brother MFC-3220C Plain Paper Inkjet Fax
Hardver problem My printer sucks plenty of black ink when changing cartridges. So it runs out quickly. Printing is very stripy as well. Shall I take it to service or can I repair it myself ? (No warranty on it any longer).
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,346 Answers
Re: hardver problem
Tough call, depending on how much you paid for it, it may not be worth it ( unless they give free estomates).
open the printer, look at where the printer head goes into home position ( where it usually ends upafter printing)
there is a sponge on the bottom, it is suposed to make contact only after it goes to home position ( this is what keeps the contacts moist so they don't dry up)
is it making contact all the time ? ( cheat the switch with the door open)
if you are not tech savvy then better to take it to a shop and get an estimate
Posted on Dec 20, 2007
0 characters
3 Points
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
Printing ok from computer but photocopier printing very faded
Select "Copy" from the touchscreen and then select "Settings..." Adjust the "Lighter/Darker" setting and see if that helps.
Mar 31, 2015 | HP Officejet Pro 8600
How do I print black with hp6600 printer? new cartridges and all colors in printer
Normally when you start to print out to printer you get a selection window on the screen. you can select Black only there.
Hope this helps.
Feb 25, 2015 | HP Hewlett-Packard - Officejet 6600...
Faded print on dell c1765nfw
Hate to sound obvious but have you tried replacing the ink cartridge?
Oct 15, 2014 | Dell Multifunction Color Printer C1765nf...
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
Let me know
Jan 09, 2011 | Brother IntelliFax-2480C Fax
Color has gone a little crazy. Printing in green etc. How to fix?
Take the ink cartridge out and clean it with little alcohol and cotton, and make sure the cartridge is reseated properly.
Let me know.
Aug 20, 2009 | Brother Fax Machines
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Brother MFC-3220C Plain Paper Inkjet Fax Logo
Top Brother Fax Machines Experts
Paul King
Paul King
john archer
Are you a Brother Fax Machine Expert? Answer questions, earn points and help others
