Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
My blackberry is frozen... it doesn't respond to me pressing buttons, and I'm not really sure if it is charging. if i take the battery out and put it back in, it takes me to my password page, but then I can't enter my password and it cuts out. please help.
  • lesleyajohns Sep 30, 2009
    Hey, How do I reload the operating system? I tried but it doesn't seem to be working
  • 51 Answers
U have to reload the blackberry. After reloading the OS, its going to be Ok
Posted on Sep 30, 2009
  • Charles Akintunde
    Charles Akintunde Oct 01, 2009
    download the operating system of BB on blacberryforums.com chooosing ur carrier after downloading run the OS on a pc. after that connect ur BB with the pc with usb. the system will detect it automatically. But make sure u delete vendor.xml file located on common file inside it u will find research in motion folder go to app folder delete all the application u have in it/
    connect ur usb, it going to ask u to update then follow the steps
How to reset
Press power button for 10 seconds at least. If it restarts, you're good to go. If it doesn't, remove battery. Press power button. Put battery back, Press power button again to start.
Aug 18, 2014 | Research In Motion BlackBerry Curver 8520...
My ipod classic 7th generation is frozen. the light is on but it doesn't respond to any buttons or the wheel. I tried to press the home button and the play button but it's not doing anything.
Hi! (: i'm not sure if this will work, but when my ipod did this, I left it in a cup of rice for a few hours, then I left it charging for a while until it turned on and showed the home screen. If this doesnt work, try calling apples technicians on their website! They can help sometimes..
[Also, yahoo answers might have a better solution] Good luck!
Dec 04, 2012 | Apple iPod classic 7th Generation
Blackberry is frozen and will not reboot with either alt+caps+del or battery pull
1-Give the Blackberry at least 1 minute without pressing any buttons or selecting any applications. Give it a chance to catch up and make sure it's actually "frozen".
2-Give the Blackberry at least 1 minute without pressing any buttons or selecting any applications. Give it a chance to catch up and make sure it's actually "frozen".
3-If the Blackberry is not "soft frozen" then it is in fact "hard frozen", which is generally where your smart phone will remain until you reboot it. To reboot open the battery door on the back of the Blackberry and simply remove the battery completely. Allow the Blackberry to sit without a battery inserted for at least 30 seconds.
4-Put the battery back into the Blackberry smart phone. It will take anywhere from 1 to 5 minutes to completely power up and become ready for use again. Your frozen Blackberry problems are now solved!
Apr 16, 2011 | Cell Phones
Just bought a new Blackberry storm 9530 and it is not getting charged. Please help
Usually for brand new phones, the battery needs to be charged for two hours. But if you found out after it's been a while and it's not charging, make sure the battery is inserted correctly. If it's and the led is not on or no charge indicator, do the following, take out the battery, unplug the charger from the phone, press and hold the power button for five seconds. This drains out the battery. Now put the battery back in, plug the charger into the phone and let charge. Don't worry if it doesn't recognize it immediately. I hope this helps
Mar 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
I hv a blackberry 9000 phone and the red light blinks but I cant switch on the phone even thouh its connected to a power adapter for charging
Take the phone off charge and take off the battery on the phone, you can now put the battery back into the phone. Press and hold the red power button on your phone. If the problem persist then go ahead and download the blackberry desktop manager unto your computer. Connect your blackberry to the computer and initiate the blackberry desktop manager. Once it shows connected as status between the phone and your BDM (blackberry Desktop Manager). Reinstall the software on your blackberry. Make sure the computer is connected to the internet.
Regards
Jan 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
Blackberry keyboard problem
Hello everyone, this problem is cause by humidity, it is solve leaving your blackberrry rest for a while without battery in a dry place. Blackberry has not mention it but it happens a lot, and it only needs a little quantity of your own sweat to put you in troubles.
Dec 28, 2008 | Microsoft Office Outlook 2003 for PC
Blackberry reset
Check out this link. http://uis.georgetown.edu/hardware/blackberry/bb.trouble.html
May 30, 2007 | RIM BlackBerry 7250
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
184 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
