Question about HP 12c Calculator
Fading Display Display fades and calc goes off when batttery holder slide panel is seated in place. Battery is new and tested strong, but blinking * asterisk is displayed in lower left display window corner with slide panel removed.
  • dale2262 Dec 20, 2007
    Same as described. Display starts on then goes away. Changed battery, manipulated battery placement, still have problem.
  • 3 Answers
Do a search at this site:
http://www.sears.com/shc/s/dap_10153_12607_DAP_Battery+Finder
You should find the right specs and replacement batteries. I believe that you have an old style battery that has a memory function. These don't.
Posted on Mar 13, 2008
    Problem Solver:
  • 6 Answers
The blinking asterik means low battery. Could be that your replacement batteries aren't full power.
What is really sounds like is a static charge problem though. If you don't have anything stored in memory that you are worried about losing, try taking the batteries out for a full 24 hours. This will let the capacitor drain and performs a static discharge. After 24 hours put working batteries back in.
Posted on Jan 30, 2008
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
LCD display is fading
Run self test and LCD test:
Power unit on while holding MENU/ESC-
press down arrow to TEST then right arrow to start.
When self test is complete use down arrow to go to LCD TEST, then right arrow to start. Press MENU/ESC for a while screen the MENU/ESC again for vertical gray bars. Press MENU/ESC 3 times to exit. The LCD unit is pn 000-145-512, $175. I strongly suggest you not attempt replacing the LCD yourself unless you are a qualified Furuno tech.
Feb 14, 2013 | Furuno 1623 Radar 16nm Range
Front panel light is fading
Had the same problem. Replaced the display board.
Apr 12, 2010 | Thermador SC302T Electric Double Oven
Fading LCD display on Polar F11
I have this problem as well! I was just googling this problem when I found your post. I have the exact same watch and have had it for 2 years. I don't expose it to the sun or heat though.
Jun 13, 2009 | Polar F11 Heart Rate Monitor
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Error code f cthermador sc301t
THE FADING DISPLAY IS A VERY COMMON ISSUE WITH TERM, BOSCH, AND JENN-AIR JUST REPLACING THE DISPLAY BOARD OR EOC DOESNOT SOLVE THE ISSUE DUE TO INCOMPATIBLE SOFTWARE YOU WILL ALSO HAVE TO CHANGE THE MAIN PWR RELAY BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | Ovens
Kenwood VR-605 display fading out
There is a cold solder connection on the display device, on the display driver board, or on or in the power supply that supplys the display voltage to the driver board. The only way you can repair it is if you have some soldering experience and or some electronic troubleshooting skills. If you go in and start poking around, and you poke at the wrong thing, It will smoke on you, as solid state electronics are very unforgiving when it comes to shorting out something, even if its for a blink of an eye!!! If you really like the unit, take it into a repair shop, as it should'nt cost to much to repair. If the units 3 to 6 years old, Maybe its time to think about upgrading to a newer unit??. Good Luck
Jul 30, 2006 | Kenwood VR-605 Receiver
HP 12c Calculator Logo
434 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
