Question about BoxWave Corporation Apple iPhone 2G Designio Leather Case
Iphone 2g stuck at slide to unlock screen
I currently have an iphone 2g with 3.1 firmware. 2 days ago it got stuck on the ''slide to unlock'' screen. It has been non responsive even though i have hard reset it as well as restored it several times. It almost seems like the bottom quarter of the screen just doesn't work, when i turn the phone off and the slide to power down screen comes on the cancel but doesn't work but i can slide to power it down. Is there anything that i could do to remedy this?
    Master:
  • 329 Answers
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Posted on Jun 18, 2017
timthorne911
  • 464 Answers
SOURCE: I dropped my iphone and now the unlock slide doesnt work
You need to buy a new phone. Dropping Iphones is a huge no no. They are very fragile. See if you can't get a replacement or if your phone company will try to fix it for you. It's a matter of the ink in the screen, something cracked and got air in it. Hope I've helped!
Posted on Mar 18, 2009
  • 18 Answers
SOURCE: my iphone 2g gives a warning that the accessory is not made for
the sound on that device is not great I have been using a charger that says its not supported for over a year. But if you hold down the top and bottom middle buttom at the same time then power off it wll do a soft reset.
Posted on May 16, 2009
  • 240 Answers
SOURCE: i put my iphone on charge, and after 5 min. i
This is because your battery is so flat it doesnt even have the power to turn off properly,and the program does often get "stuck" when this happens. Remove the battery, recharge the phone and it should be ok.
Posted on Jun 15, 2009
  • 226 Answers
SOURCE: I dropped my iphone, screen is in tact, slide bar won't work
you can get the slide part changed . it could cost you anywhere near 100 $
Posted on Oct 21, 2009
bdouglas
  • 290 Answers
SOURCE: I have an iphone 2g that is frozen on the apple
Try press and hold power button till it turns off and then turn on while holding home and power for 10 seconds and then release power button only and hold home still for 30 seconds. It should put phone in DFU recovery mode and then iTunes should see it. Once it does, re-install latest OS.
Posted on Jun 12, 2010
My iphone 2g has no sim card in it but it is stuck on the page where when i slide to unlock its only for an emergency call
It seems that your iPhone 2G is in need of activation. To accomplish this, there are 2 ways:
A. (With AT&T as your service provider)
1. If you do not already have an AT&T sim card, contact AT&T and ask for an AT&T sim card to activate service with them. Choose your plan and insert the sim card in the iPhone.
2. Connect the iPhone to iTunes and you will be prompted to follow a few steps to proceed with the activation process.
3. Sync your iPhone for the first time.
Once completed, you will have your iPhone activated and ready to use on the AT&T network.
B. (Without AT&T as your service provider)
1. You will need to download an application to jailbreak your iPhone. (This will essentially remove certain restrictions on your iPhone 2G that prevent you from utilizing your iPhone on another network, among other things).
2. Connect your iPhone to the computer and run your jailbreak application of choice.
Once completed, your iPhone 2G will be activated and jailbroken. The "emergency call" message will disappear, though you will be prompted with a "no sim card found" message until a sim card from AT&T (or another GSM carrier) is placed in the sim tray.
Aug 11, 2010 | Cell Phones
Iphone showing no service
If it was bought unlocked for under $700 then it was unlocked illegally after updgrading to 3.0 it is locked again. If you upgrade to any of appples unpdates your phone will be locked each time and you will have to wait for an unlock solution to be released each time. Currently there is no way to unlock the 3g under 3.0 firmware only the 2g is unlockable to the 3.0...I know case i have one. Jailbreaking and unlocking are different.You have to downgrade your firmware to unlock it. Restore your phone via iTunes using one of your old backups, you should be fine.
Jun 26, 2009 | Apple iPhone 3G
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Jun 20, 2009 | Apple iPhone Smartphone
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
Frozen screen on 2g iphone 8gb
if it is the 2g model it is still reversible
  • you will need to unlock it and you will be fine
if it is the 3g model you are stuck at the min
Feb 18, 2009 | Apple iPhone Smartphone
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
its not a hardware problem brothe as i am also facing same problem...actually it all happen with jailbreaked iphone...ad i'hv checked its deep root directory there an application called "lockdown" is the main cause of that...nd still there is no crack of that.....
two days back i unlocked my iphone 2g it was working properly before that i was facing the same issue as you are facing....but now again it went to the same problem....
i hav a temp solution of that...
use blackra1n u can find it from blackra1n.com
nd for few seconds slide to unlock will work
or u can use it by connecting it with ur itunes ...connect usb wire nd slide it again nd again...u can unlock it..bue its just temp
Feb 04, 2009 | Computers & Internet
My iphone is stuck amd will not go to home page
Cause it is in restore mode. If you have a 2g use this tutorial to unlock your phone with the 3.0 update.
If you have a 3g use this one currently you can not unlock a 3g under the 3.0 firmware.
Jan 11, 2009 | Apple iPhone 3G
I have an iphone that does this at times too! I have to reboot it periodicly, seems more often when I use it a lot. I have found several issues with winterboard and plugins for it to cause some of my problems. might try changing your screen to normal and see if it still acts this way.
Dec 20, 2008 | Apple iPhone Smartphone
Iphone unlocked problems
i just purchased an unlocked i phone 1st gen and it was working fine with my tmobile carrier but all of a sudden i synced it with i tunes and now it wont let me make calls
Oct 11, 2008 | Apple iPhone Smartphone
BoxWave Corporation Apple iPhone 2G Designio Leather Case  Logo
1,087 people viewed this question
Top BoxWave Corporation Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
Andrew Taylor
Andrew Taylor
Are you a BoxWave Corporation Cell Phone Expert? Answer questions, earn points and help others
