Question about Whirlpool RF378 Electric Kitchen Range
Looking for replacement burners for Whirlpool model RF302BXDN 0 range.
  • daniel  hendrickson
    daniel hendrickson May 11, 2010
    appliance parts pros website or 1-877-477-7278 /whirlpool 6" element # AP3866515 for the 8" element part # AP3866514
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
I have an old propane stove/ range in the house we are renting and we cant read the dials to see what temp the oven is or evan if it is on bake we need to know the only number we found was 35-300243-05-0...
I found the following numbers on my Whirlpool Range:
Quality Control Reference: 35-300243-05-0 (Back of range)
Warning Sticker: 35-302251-05-0
Model: SF380PEWQ0 (Under removable burner lid)
Serial: FFE0204680 (Under removable burner lid)
MFG No.: P1141260N Q (Under removable burner lid)
Whirlpool has the manual here: http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%204363409.pdf
Whirlpool has the parts list here: http://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%204363637.pdf
Dec 18, 2010 | Kitchen Ranges
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool RF265LXT Range
I have one burner out but wired correctly
test power on wires to burner should be 110/120volts if 0 replace switch...thumbs up
Aug 15, 2009 | Whirlpool RF379 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
1 coil heats, the other 3 don't
Take a flashlight & look into the receptical where the burners plug in. If it looks burned up, then you need to replace the recepticals(part #330031). If the burner prongs are burnt looking, they need to be filed clean or replace the burners too. If you plug burnt burner ends into a new receptical, it will burn the receptical in no time. Try spreading the prongs on the burners before plugging them back in to make a tighter contact.
Jan 12, 2008 | Whirlpool RF365 Electric Kitchen Range
Whirlpool RF378 Electric Kitchen Range Logo
360 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
