Question about Hayward SAND FILTER, PRO SERIES
Sand is getting into the pool. What could be the problem?
    President:
  • Hayward Master
  • 1,378 Answers
The lateral assembly inside the filter is bad and needs to be replaced. Replace the sand while you are at it unless it is only a year or two old. Be sure to fill the tank half way with water before adding sand back in to avoid damaging the new lateral assembly. If you can send me the filter model number we could quote you the part at www.arrowpools.net.
Posted on Oct 01, 2009
Can the filter blow sand into the pool?
If you are using a sand filter and if the plumbing is incorrect you can flush sand into the pool instead of flushing dirt down the drain. If you are using a sand filter and the sand support screen material is torn you can get sand into the pool.
Dec 05, 2014 | Pool & Spa
Sand is getting into the pool.after trying sand removal cleaning the "fingers" and making shore they were all connected what else could it be?
If you are getting sand back into the pool from what you have described and there are no holes in the lateral fittings then the gasket on your multiport valve is worn out and needs to be changed.
Rod
US Parts Center
Apr 17, 2013 | Hayward 3/4hp Super Pump Inground Pool...
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
HAYWARD SAND FILTER, PRO SERIES: sand is getting into the pool whan the filter is r...
Have you tried backwashing recently? If so, I would first check to make sure that your pool filter is on the "filter" setting and has not been changed. Next, i would evaluate your filter pressure to make sure that it is at an acceptable level. Finally, check your sand. If it is extremely dirty or has not been replaces in a long time, it might be time for fresh, more effective sand.
May 17, 2010 | Hayward SAND FILTER, PRO SERIES
Service a pool sand filter
Sand should be changed in a sand filter every 3-5 years. If you have alot of debris/vegetation getting into the pool it will be closer to 3. #20 silica sand is recommended. You have to remove all of the sand from the filter and refill it with new sand. Make sure to fill the filter with water up to the level of the lateral assembly to avoid breaking a lateral. If you're uncomfortable doing this, a competent pool professional should be able to provide this service for you.
Nov 22, 2009 | Harmsco Pool and Spa Cartridge for Filter...
Cloudy brown dirt getting in my pool from sand pump
The dirt you are getting is most likely from the air, dirt and dust present in rainwater and the small amounts present on human bodies. It is settling out and going to the bottom. I recomend a vacuum attachment that connects to your pump/filter to keep this cleaned out. Basically it "plugs In" to the outlet on the pool and will get all that out for you.
Aug 11, 2009 | Hayward SAND FILTER, PRO SERIES
Dirt comes back thriugh the return when I vacuum
if your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
Jul 16, 2009 | Hayward SAND FILTER, PRO SERIES
Sand is in pool after backwash
A little sand is normal, called a puff back. Anything more then a good pinch of sand is a problem If its a lot of sand you can check the following.
1. O-ring in side the filter valve when standpipe inserts is intact. Make sure that standpipe is not cracked and seats well into valve.
2. check spyder gasket inside filter head. (looks like a wagon wheel) if it is loose or is pulling up it will need to replaced or re-siliconed. A good indication of this being the problem is if water is leaking from backwash port.
3. Check hoses to make sure that the to pool, to pump conections have not been reversed, if this was case you would get a lotta sand into pool. (can empty tank)
Jul 04, 2009 | Hayward Pro Series 18" Above Ground Pool...
Sand from the filter is getting into the pool.
u are getting sand in to your pool most likely because u have a broken lateral i nthe bottom of your filter.
Jun 07, 2009 | Hayward SAND FILTER, PRO SERIES
There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Mar 01, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
106 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
