Question about Anti-theft Alarm System 3 Series E90 E92 Bnib
1995 5 series BMW - alarm goes off and car will not start what do I do?
  • Anonymous Mar 28, 2014
    alarm system T3
  • 72 Answers
That may be the immobiliser kicking in. If you have an led does it flash a code at you ie 2 flashes, short pause, 2 flashes etc ? This sequence indicates a hood or boot switch normaly.
Posted on Oct 15, 2009
My car is a bmw 540i 1995 and I like it very much! I was told that the one and six is missing! How do I find out which one is the six and one?
First thing i would do is to take the battery clamps off and clean them and then clean the battery post themselfs. If that dont work then i would look for a bad ground to the motor.
Nov 26, 2012 | 1995 BMW 5 Series
How do i reset my alarm on my bmw 3 series without fob
engine management should read the transponder chip in your key and deactivate the alarm the battery in the key is charged while key is in ignition if the key hasn't been used for a while maybe its flat
Jan 14, 2012 | BMW 3 Series Cars & Trucks
Where do i fill the transmission fluid on my 1995 bmw 850 series
Fiil fluid through same tube as the dipstick goes into, just like any other automatic trans.
Apr 13, 2011 | 1995 BMW 8 Series
2000 BMW X5 will not start due to the alarm going off twice. What is the procedure to get this fixed?
if the key is good there should be no reason for it not start,the alarm will not lockout.is the engine cranking?
Feb 08, 2011 | 1995 BMW 3 Series
I have a 97 BMW 528i... When I put the key in the ignition the lights on the panel blinks real fast and the car makes clicking noises. The car doesn't even start. And from time to time the car alarm goes...
Check your battery. Check to make sure that the computer under the hood in the front dash is dry and properly connected. Another common failure of the alarm system are the door latches. (the latches have a micro switch in them that tell the system when the doors are shut)
Jan 20, 2011 | 1 Series Vehicle Alarm System
I need to locate the keyless alarm converter box in my 1995 BMW 530i because my keyless remote transmitter is not working.
if key fob not working change battery as to keyless entry module location and accessing it notify a dealer its part of ur security system and tampering with it can cause u to disable ur vehicle to the point of having it towed because ur locked out from starting it
Feb 02, 2010 | 1995 BMW 5 Series
Battery died, charged it when hokked up it tripped the alarm.
way round it maybe to just disconect it, or look for the fault probably a loose wire, or a bare wire rubbing of the metal work setting it of, best to fit a new 1
Jun 05, 2009 | 1995 BMW 3 Series
Car Alarm keeps going off on 528i (1999)
I had a similar problem, 2003 530i, but only while the alarm was active. The culprit was a bad hood switch that was making intermitent connection.
May 28, 2009 | 2003 BMW 5 Series
Change out radio now it won't start. both radio's are after marke
check all your fuses to make sure you didnt burn out the main one.
it sounds like the car has an aftermarket alarm or the bmw immobilizer alarm. see if there are any relays that are not original mounted under the driver's knee plate and connect to the heavy gauge red wire which goes to the starter relay soleniod.
Mar 07, 2009 | 1987 BMW 3 Series
88 735 Alarm won't let me start car and I don't have remote.
I had a 740 il bmw 97 befor it won't start turn the key juste the light in the dach on now tech on bmw had it start but the alarm still on tell the cause of it what can ido to to stop the alarm
Mar 01, 2009 | 1998 BMW 7 Series
Anti-theft Alarm System 3 Series E90 E92 Bnib Logo
507 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
