Question about Jenn-Air Refrigerators
Our Jenn-Air refrigerator appears to be leaking, as evidenced by buckling floor boards in front of and behind the refrigerator in the next room. This double door fridge (top), freezer bottom was new in Oct. 2007: it has a cold water delivery system with a filter (upper right) and a push-button faucet on the left panel. Can the water be turned off? Have you a local specialist repair person in Louisville, KY? David Mann (ddmann1@bellsouth.net) or (502) 896-1751.
  • 615 Answers
The water can be off and not use it tell you find the leak. I am checking now with Jenn-Air dealer for best repair facilities close to you so you can pick one. Let me know if you need to go further with it. Please do not forget to rate our service so we can continue helping everyone
Posted on Sep 30, 2009
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
Water freezing on floor of freezer and leaking on to floor in front of freezer?
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Feb 18, 2011 | Jenn-Air JSD2789GES Side by Side...
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
Water leaking from jenn air refrigerator side by side
check the freezer side and see if there is ice under bottom rack and floor if so you have a clogged drain,follow the floor to the back wall and the bottom of back wall panel,there is a drain there,use hair dryer to melt out and then you need a steamer or something to blow out the drain line,check it by pooring hot water in the drain you'll know if you unclogged it if the water drains through
Nov 01, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
62 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
