Question about Cameras
A green line is being display on the LCD display.
One green vertical line is being display on the LCD display. However, this line does not affect the picture. My camera is Nikon L1.
    Scholar:
  • 96 Answers
That is a faulty LCD panel, if it's under Warranty, then take it in for service, if not, I wouldn't bother as it is costly (but up to you)
Cheers.
Posted on Oct 01, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Vertical line
the LCD is not work well
you can do follow these:
1,reconnect the LCD cable (It is connected to the motherboard and LCD screen)
2,if the vertical line is still there,it means that the LCD is bad ,you need a new LCD
Feb 09, 2014 | Hitachi Ltd Projector, Hitachi,...
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vertical green line in display
This is a hardware issue. If it's under warranty, no problem, get it fixed. Otherwise, you can either put up with it or replace the unit. LCD displays like this are so inexpensive now that it no longer is cost effective to repair them.
May 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cameras Logo
133 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
