Question about Dishwashers
The dishwasher is not working. When the cycle is finished the dishes are still dirty and the soap is lying in a pile at the bottom of the washer still dry. It is a GE Medallion 850 Model#GMB8240KD119. how old is this model? Do you recommend fixing or replace?
  • 2,841 Answers
The float switch may be the problem so open it up and clean it. Debris can cause the float to stick in the raised position, which prevents the tub from filling which appears to be your problem. If the water doesn’t reach the right level (just covering the heating element), the dishwasher won’t clean well. On most models, you’ll find the float switch in the lower front of the tub. Some have a cover, but some don’t. You may have to use a small, flexible brush or pipe cleaner to clean those without a removable cover. When clean, the float should slide up and down freely. It can also be a clogged intake valve screen. So before going through the somewhat more complex steps for cleaning the intake valve screen, check the water level. Close the door, turn on the machine and run it until it’s done filling during its second cycle. Then open the door (the machine will automatically shut off), and check the water level. If the water doesn’t come up to the heating element, it’s too low. Close the door and let the machine cycle on through. Then proceed to clean the intake valve screen. You’ll have to unhook several wires, so always begin by turning off the electrical power to the dishwasher at your main panel. Turn off the water supply to the dishwasher as well. Usually the shutoff is at the hot water supply line under a nearby sink.
The inlet valve is usually mounted on the underside of the dishwasher near the front. You have to remove the lower panels and disconnect the valve to get at the valve screen, a wire screen mounted within the body of the valve itself. If the wires don’t pull off readily, push the small spot in the center of the connector to release them. And mark one wire and its terminal with tape so you can get them back on the same way.
TIP: Keep a rag handy. You’ll have to mop up a bit of water when you unhook the copper supply tube.
Some pros prefer to simply replace the valve on old machines to avoid problems in the near future. New valves cost about $15 for most machines. Look under “Appliance Parts” in your Yellow Pages for sources. Stick the end of the supply tube into a pan and turn on the water supply briefly to flush out sediment before reconnecting the supply tube. Put everything back together and see if this helps.
Posted on Sep 30, 2009
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Bottom thing is not turning... suds is running
YOU ARE USING WRONG DETERGENT IF YOU HAVE SUDS TO THAT EXTREME, OR DETERGENT LEFT ON ONE OF THE DISHES. CAN'T SAY THAT I HAVE EVER SEEN ANY SUDS IN A DISHWASHER THAT USED DETERGENT MADE FOR A DISH WASHER. THE SPRAY ARM WILL NOT TURN AS THE IMPELLER CANNOT PUMP AIR (SOAP BUBBLES).
Mar 09, 2010 | GE Dishwashers
Kenmore Dishwasher doesn't rinse? It sounds to be working fine, however, at end of cycle, dishes are still dirty, and the front door on the inside is still dirty. Obviously there is a problem here...
try opening the dishwasher during the wash cycle stop it and open it if water is in the bottom it is filling whn you open do 1 or 2 times to check to see if spry arms are spinning if they are check to see if soap dispenser is working also use dishwasher cleaner once a month available wherever tou shop for groceries in the dish soap dept. directions are on label
Dec 15, 2009 | Kenmore Dishwashers
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
Dishes left dirty - possible blockage
You can probably either unscrew a knob and remove the wash arms or they'll snap off and on. Take off the wash arms and make sure there aren't big chunks of food collected under there. If there's a plastic washer in the wash arm assembly, and it's looking worn, you'd be surprised how much quieter and better your machine will run by replacing it.
Sep 20, 2009 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
Owen Barnes
