Question about Toys
Yoke puzzle solution - Toys
  • 346 Answers
I found a solution to a "Ox Yoke Puzzle. I am not sure if this was what you wanted or not. I couldn't find anything just labeled Yoke Puzzle. It would have helped more if there was more information. Here is that solution....
1. pull the center loop down a couple of inches
2. move right ring/ball through the hoop you made from the center string, and let go of the ball so it is behind the loop.
3. take the entire loop and push it through the center hole and pull all turns through.
4. feed ring through two loops on back side of yoke.
5. pull entire center loop back through the center hole.
6. straighten all loops, and right string will be on the left loop.
*. to return, reverse steps!
i hoped this worked for you!
Posted on Sep 30, 2009
  • hawkeye70 Aug 05, 2011
    I sure would like sketches to view
What is another word meaning team
club
company
lineup
organization
party
side
squad
unit
aggregation
band
body
bunch
contingent
duo
faction
gang
outfit
pair
partners
rig
sect
set
span
stable
string
tandem
trio
troop
troupe
workers
yoke
Jul 19, 2014 | Toys
I have a simple problem with the SAITEK pro flight yoke. The LED display does not turn on. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LED DISPLAY. ...
For how low have you had the Yoke?
This a known fault with the front display on the Yoke failing, it's caused by the LED's being faulty or a inperfect contact there.
If the Yoke functions correctly then it might be one of the above.
If you still have warranty, meaning if you purchased the Yoke less then 2 years ago, try to ask for a replacement for it either from the retailer of from Saitek.
hope it helps...
Apr 03, 2011 | Saitek Pro Flight Yoke System Flight...
Hi there I plug flight yoke into usb and get no recognition and no power even the green led on yoke does not light?? however if i plug the throttles in the light does come on on the throttle assy (small...
The yoke has effectively got a USB hub built in, and it sounds like your throttles are getting power from the hub okay, but the yoke is not. Suggest you return it for a replacement to Saitek
Mar 26, 2010 | Saitek Pro Flight Yoke System Flight...
How do you get the rear u-joint out of the drive shaft on 2005 chevy avalanche
It will need to be pressed out.
Universal Joint: Service and Repair
Nylon Injected Ring
Universal Joint Replacement - Nylon Injected Ring
^ Tools Required
- J 9522-3 U Joint Bearing Separator
- J 9522-5 U Joint Bearing Spacer Remover
Disassembly Procedure
Notice: Never clamp propeller shaft tubing in a vise. Clamping could dent or deform the tube causing an imbalance or unsafe condition. Always
clamp on one of the yokes and support the shaft horizontally. Avoid damaging the slip yoke sealing surface. Nicks may damage the bushing or cut
the lip seal.
1. Support the propeller shaft in a line horizontal with the table of a press.
2. Mark the propeller shaft as to which end is the transmission end and which end goes to the rear axle.
3. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1 1/8 inch) socket.
4. In order to shear the plastic retaining ring on the bearing cup, place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out
of the yoke ear.
5. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue to press the bearing cup out of the yoke.
6. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
7. Mark the orientation of the slip yoke to the tube for proper reassembly.
8. Remove the cross from the yoke.
9. Remove the remaining universal joint parts from the yoke. If you are replacing the front universal joint, remove the bearing cups in the slip yoke
in the same manner.
10. Inspect the retaining ring grooves for plastic.
11. Inspect the bearing cup bores in the yoke ears for burrs or imperfections.
12. Clean the remains of the sheared plastic bearing retainers from the grooves in the yoke.
13. The sheared plastic may prevent the bearing cups from pressing into place and thus prevent the bearing retainers from properly seating.
Assembly Procedure
1. Remove the bearing cups from the universal joint.
2. Assemble 1 bearing cup part way into 1 side of the yoke.
3. Turn the yoke ear toward the bottom.
4. Assemble the cross into the yoke so the trunnion seats freely into the bearing cup.
5. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
6. Assemble the opposite bearing cup part way into the yoke ear.
7. Ensure that the trunnions start straight and true into both bearing cups.
8. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for a free unbinding movement of the
trunnions in the bearing cups.
Important: If there seems to be a hang-up or binding, stop pressing, and inspect the needle bearings for misalignment in the bearing cup.
9. Press the bearing cup into the yoke until the bearing retainer groove clears the inside of the yoke.
10. Assemble the bearing retainer in the retainer groove.
11. Continue pressing until you can snap both retainers into place.
12. If seating the retainer is difficult, spring the yoke slightly with a firm blow from a dead blow hammer.
13. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so the snap ring seats in the bearing cup groove.
External Snap Ring
Universal Joint Replacement - External Snap Ring
^ Tools Required
- J. 9522-3 U-Joint Bearing Separator
- J 9522-5 U-Joint Bearing Spacer Remover
the lip seal.
2. Mark the propeller shaft in order to show which end connects to the transmission and which end goes to the rear axle.
3. Disassemble the snap rings by pinching the ends together with a pair of pliers.
4. If the ring does not readily snap out of the groove in the yoke, tap the end of the cup lightly in order to relieve the pressure from the ring.
5. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1-1/8 inch) hex head socket or a 27 mm (1-1/16 inch) socket.
6. Place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out of the yoke ear.
7. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue pressing the bearing cup out of the yoke.
8. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
9. Mark the orientation of the slip yoke to the tube for proper reassembly.
10. Remove the cross from the yoke.
11. Remove the remaining universal joint parts from the yoke.
12. If you are replacing the front universal joint, remove the bearing cups in the slip yoke in the same manner.
13. Inspect the retaining ring grooves for dirt, corrosion, or pieces of the old ring.
14. Inspect the bearing cup bores for burrs or imperfections.
15. Clean the retaining ring grooves. Corrosion, dirt, rust, or pieces of the old retaining ring may prevent the bearing cups from pressing into place o
Assembly Procedure
2. Assemble 1 bearing cup part way into 1 side of the yoke. Turn the yoke ear toward the bottom.
3. Assemble the cross into the yoke so that the trunnion seats freely into the bearing cup.
4. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
5. Install the opposite bearing cup part way into the yoke ear.
6. Ensure that the trunnions start straight and true into both bearing cups.
7. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for free unbinding movement of the
Important: If there seems to be a hang up or binding, stop pressing. Inspect the needle bearings for misalignment in the bearing cup.
8. Press the bearing cup into the yoke until the bearing cup retainer groove is visible over the top of the bearing cup.
9. Assemble the bearing retainer in the retainer groove.
10. Continue pressing until both retainers can be snapped into place.
11. If the retainer is difficult to seat, the yoke can be sprung slightly with a firm blow from a dead blow hammer.
12. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so that the snap ring seats in the bearing cup groove.
Oct 30, 2009 | 2005 Chevrolet Avalanche
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
Puzzle Master's House won't open
You haven't solved all 132 puzzles
The game tells you (both in the trunk and in the save slot) how many puzzles you've both found and solved
Players who think they've solved all 132 puzzles usually just look in the game's puzzle list, see that the last puzzle there is 132 and mistakenly assume that they must have solved all 132 puzzles
The puzzle list only shows those puzzles that have already been found, not every puzzle
Unless the found/solved count shows 132/132, then the last puzzle house will not open
If the game says, for example, that you've only solved 131 puzzles, then you have to very carefully look through the list to find the missing puzzle number ... if you don't find it, look again (some players have had to look through the list multiple times before spotting it)
Once you have the missing puzzle number, check this walkthrough to quickly find where the puzzle is (if it's not in Granny's shack)
http://professorlaytonwalkthrough.blogspot.com/
There's a puzzle index down the right side of the walkthrough you can click on
On a side note, this walkthrough can also be used for more puzzle solving fun, by looking at those puzzles that are specific to the other version (US/UK) of the game (there's over 180 puzzles between the versions)
May 11, 2009 | Nintendo Professor Layton & the Curious...
Finding all 120 hidden puzzles...
When the game says that you've solved 131 puzzles, then you've solved 131 puzzles
Players forget that the puzzle index only shows the puzzles that have been found ... just because the last puzzle in the list says 132 doesn't mean that there's 132 puzzles in the list
You have to carefully look through the list to find the missing puzzle number ... if you don't find it look again (some players have had to look through the list multiple times before spotting it)
Apr 21, 2009 | Nintendo Professor Layton & the Curious...
Puzzle locations
Puzzle 091 Underground Area-- down the manhole near the giggly little girl
Puzzle 092 Sewer Dead End---- down the manhole
Puzzle 115 Abandoned Tent. ----
Puzzle 118 Village Hall -------
Puzzle 120 In the Sewer ----- down the manhole
I also have answers if you get stuck....................
Mar 10, 2009 | Nintendo Professor Layton & the Curious...
MITSUBISHI MODEL NO. VS-5043 BOWED AT TOP AND BOTTOM.
This is a convergence problem. The output ic needs to be replaced.
Apr 01, 2008 | RCA HD52W59 HDTV Projection Television
Toys Logo
1,695 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
