Question about Duplo Office Equipment & Supplies
I have a Duplo DBM100 booklet maker with twin stapling heads. The staples are not fully closing, i.e. the two ends of the staple are standing proud, not being bent back to the surface of the book. is there an adjustment somewhere to rectify this problem. Peter
This machine uses a nylon cam driven by a motot to raise the clinchers and close the staple legs. Often the nut on the back of the shaft that runs in the cam will come loose or the bracket will fatique and bend. A bit of a pain to get to but a little work and you will see haw the staple / clinching drive works.
Posted on Jun 12, 2012
I know this post is old, Did you solve your problem?
Posted on Sep 24, 2010
How do I change staples in a bizhub600
Depend on which staples. Saddle stich (example, Church service program with staples in the middle type) or booklet/corner with the staple on the left side or the corner. open finisher pull out the big section to the left side see to blue/green handles rear one is for corner staple which goes the fastest do to being used the most. when you pull them out there is a plastic guide they should follow if they don't line up power off the machine close all door power on machine. the stapler should go to default location which allows the staple cart. to be removed. DO NOT THROW THE CART AWAY!!!! YOU will be replacing the staples in the cart. Once out Push at he bottom pull the top. DO NOT PULL THE WHITE WRAP ON THE NEW STAPLE UNTIL INSTALLED in the cart. Had customer do that staples spilled on the floor customer installed the staples in the wrong direction.
Also be careful the is a tiny black accurator the mite come out keep it that's what tells the copier the staple is installed give to technician to reinstall.
Feb 10, 2014 | Konica Minolta Bizhub 600 750 Image...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Jan 07, 2013 | Duo Fast Duofast Carpet Pro Electric...
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Master mechanic electric staple gun tre-300-mm
1. To load the Master Mechnic TRE 300, (photo) first put on your safety glasses and then unplug the tool to prevent an accidental actuation while you are working on it
2. Always use the right size and kind of staples or brads.There is or should be a label (photo) letting you know which staples are the right ones for this tool. If it is there, you will find it on the side of the "head", the cylindrical structure with the red cap on the top, just ahead of the trigger. The "tail" is the end where the electrical cord comes into the tool. If the label is missing, there is a very comprehensive color-coded chart here http://crainshawsupply.com/ESW/Files/Staple_guide.pdf that should help you figure it out.
3. There is a chromed steel "shoe" running the length of the tool on the bottom, from tail to head, that contains the strip of staples and a simple mechanism for moving them into firing position one at a time. This is where you load staples. Observe that at the head end of the shoe, there is a little area of raised bumps and a notch. (photo) The bumps are there to provide some grip (see step 5). The notch locks the shoe into the right position for using the tool (see step 7).
4. The staple compartment is held closed by a small leaf spring (not visible) inside the tool at the tail end. The spring pushes against the staple compartment, pushing it forward against the head end and engaging the notch in the chromed shoe with a mating notch in the black plastic tool body.
5. To open, grasp the chromed shoe and push it straight back toward the tail. This will compress the leaf spring that you can't see, and will open the notch, permitting the head end of the shoe to pivot down and away from the head. The shoe will remain attached at the tail end by a small pivot pin that acts like an axle.
6. As you pivot the shoe to open it wide, you will see a movable "follower" and a second spring, a coil spring. (photo) The coil spring puts tension on the follower. The follower in turn pushes the strip of staples firmly against the head. By doing so the second staple in the strip is moved into position to be driven as soon as the first staple is fired and gone.
7. To load, open the shoe all the way. (At this point, if you see a staple jam or some debris in the shoe, you should remove it before attempting to load any new staples.) The follower will move all the way back toward the tail and stay there, but it doesn't take much to send it zooming back toward the head, so be careful. Turn the gun upside down and drop a strip of staples, points "up" (facing up as the tool is upside down), into the channel formed by the plastic body of the tool. Leaving the tool upside down, slowly and carefully swing the shoe back into the firing position and push it firmly into place until the chrome notch fully engages with the plastic notch.
8. Check your work, plug it in, and you're ready to go.
Nov 25, 2012 | Stanley Tools & Hardware - Others
I have a Pro Sharp Shooter TR 200. WHILE I HAD TROUBLE loading the staples in, I think I have them in properly, the staple cartridge door is closed but the staples aren't coming out. What am I doing...
Make sure that you are using staples made for this tool. Remove the staples and look for a jammed staple at the drive head which will block further staple movement. Make sure there is spring tension at the rear of the staple row when the slide is closed. Hope this helps!
Oct 15, 2010 | Stanley Garden
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
What does saddle stapling mean?
Saddle stapling is making a book of pages by stapling the spine at the back of the document to keep many pages together.
Apr 28, 2009 | Canon imageRUNNER 2200
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
420 people viewed this question
Top Duplo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
