Question about Intel Desktop Board D845BGL Motherboard
WHAT RAM FOR AN D865GL - Intel Desktop Board D845BGL Motherboard
    President:
  • 1,187 Answers
Intel specs:
http://www.intel.com/support/motherboards/desktop/d865glc/sb/CS-027110.htm
It supports DDR400, DDR333 or DDR266 SDRAM DIMMS
(DDR400 is the best)
Posted on Sep 30, 2009
My system doesnt see the ram i installed,(512x2) its perfectly compatible,still it only sees 448 MB out of 1024.i updated bios and everything.is it coz i am using the on-board graphics adapter?help me out...
It looks like your computer is seeing only one 512Mb RAM module. Your computer uses shared RAM - 448Mb RAM is available for the computer and 64Mb is reserved for video RAM (448 + 64 = 512Mb) of RAM.
One of the RAM modules may be faulty. To determine which RAM module is faulty, remove both RAM modules and insert one RAM module at a time to determine the faulty RAM module.
If both RAM modules are OK then -
Some computers do not like mixed RAM modules from different manufacturers. Try using the RAM modules with the same make and type/speed.
Jun 14, 2011 | Computers & Internet
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your...
put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
Nov 09, 2010 | MSI P965 Platinum (7238010) Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Ram problem?
Most likely your system has UMA video (Unified Memory Architecture) which means that system RAM is used for Video. Many systems dynamically allocate RAM resources to the Video, thus you get the varying amounts of RAM accessible indicated. This is a normal function and system is working as designed.
Oct 03, 2009 | Computers & Internet
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
Soundcard, modem driver and video controller (vga compatible)
Turns out this Model uses a motherboard manufactured and directly support by Intel.
Your Motherboard is an Intel Model # D865GL
you can find all the drivers for it at the following link
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=950&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
hope this helps you out,
Dave
Nov 20, 2008 | Computers & Internet
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Restart win operating
Have a look at the bios and see if it loses the time, it may be the cmos battery is flat, and also in the standard cmos settings, enable Halt on all Errors and it may give a clue to the fault.
Dec 18, 2006 | Intel D865PERL Motherboard
Intel Desktop Board D845BGL Motherboard Logo
139 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
