Question about Epson Stylus Pro 9600 InkJet Printer
It will run fine for a while, then splatter ink all over in random places.
2 Suggested Answers
cns assoc
  • 677 Answers
SOURCE: Black ink is splattered randomly at spots around
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
I found this on fixya per dgsturt
It looks like you've managed to get ink all over the shop by using the self clean option. That't mainly to clear bocked print heads and tends to squirt a load of ink through.
That ink has to go somewhere, it looks like you may have some on your rollers.
First, I'd have a look through the printer menu see if there's a roller cleaning option, give that a go.
Second, I'm not sure but worth a try, try printing a document that has wording all down the page but use an empty cartridge. If your printer will do this you’re effectively using a sheet of paper as a mop to clean the rollers.
Third, probably the most difficult, get some Isoproprial Alcohol from the chemist and try and clean the rollers and print bed yourself with a lint free cloth and cotton buds, what ever works.
If you don't like the idea of Isoproprial Alcohol, it is highly infamable, try with a damp cloth first, but it will take longer to dry off.
pls rate me.
Thanks
Posted on Mar 23, 2010
When printer a document the ink is splattered/smudge all over the paper...help??
run the printing head cleaning routine in the printer's utilities you have installed on your computer
usually this fixes the problem if you didn't mess up with refilling the cartridges
Mar 02, 2011 | Office Equipment & Supplies
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Ink splatters from new toner
Clean the drum unit cartridge and the charge roller unit.
Apr 15, 2010 | Minolta DI2510 Black and White Copier
Looks Like Ink splatter on my TI-83+ screen!
The screen has probably sustained a severe chock. It is very likely that it is damaged. For information about the availability of repairs in you area of the world, contact TI by email at ti-cares@ti.com.
Hope it helps.
Thank you for using FixYa and rating this solution.
Nov 18, 2009 | Texas Instruments TI-83 Plus Calculator
Ink pen splattered in Kenmore front loader washer...
I would try running a few empty cycles with some oxyclean through it...
Jul 08, 2009 | Kenmore Washing Machines
Black splatters all over paper
Have you changed the cartridge? Sounds like a bad seal after it was refiled or the nozzle went bad on the black ink. Try replacing the cartridge.
Jul 08, 2009 | Office Equipment & Supplies
Dell Photo 924 All In One Printer
Have you place the ink cartridge at correct place . Check it and tell later
Jun 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
Duel fuel runs perfect on gas. petrol not so good coughs and splatters when you place your foot down Yet idles smooth, could it be the mass Air sensor?
Do you have OBD 2 emission system? Have you taped lightly on the MAF Sensor to see if engine sound changes? If the system is OBD 2 you can disconnect the MAF and the PCM computer will subsitute a signal for the MAF sensor and the engine will run fine, try that and get back to me.
Jul 24, 2008 | Jeep Cherokee Cars & Trucks
Black ink splattering the sides of the paper
remove ink cartridge wipe off print head area with rubbing alcohol
applied to a microfiber cloth
Jan 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Pro 9600 InkJet Printer Logo
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
