SkyScan Atomic Clock model #86730
I have a SkyScan atomic clock model #86730,which stopped working. I put new batteries in, but still shows nothing. Please help.
SOURCE: I have a87900 model skyscan,can;t get it reset after replacing batteries
http://www.skyscaninfo.com/content/
they have instructions online
Posted on Sep 04, 2008
SOURCE: Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Posted on Mar 14, 2009
SOURCE: skyscan atomic clock model no 88902
Instructions for setting the clock can be found at:
http://skyscan.info/content/index.php?option=com_content&task=view&id=57&Itemid=40.
Posted on Apr 12, 2009
SOURCE: my clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Posted on Nov 23, 2009
SOURCE: skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Posted on Feb 01, 2010
How to change day of the week on skyscan atomic clock 86709r model
Generally on ATOMIC sourced/synchronized
clocks you need only properly depict your
TIME-ZONE and year...
If you are in the USA
THE BELOW (similar) FREE
SKYSCAN instructions might help...
No exact matches found Showing results for skyscan 86
SkyScan 86730 Instruction Manual
Carnac the Magnificent
Jun 13, 2017 | Home
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
Hello
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-manuals
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
I have a atomic clock and dont know how to set it
I have a skyscan Atomic clock model no 86730 and can't set it, every time i get it set, it goes back 1 hr, i need to know to set it to daylight savings time
Mar 17, 2010 | SkyScan 86742 Digital Atomic Wall Clock
My clock is nort showing up the outside tempertute
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
How do i set my clock
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
Sep 02, 2008 | SkyScan 86709 Atomic Wall Clock
213 people viewed this question
 Grubhead
Grubhead
