Question about Kenmore Washing Machines
Model 110.27802690 stopped after rinse, still full, won't respond. Checked power source, won't work in any switch position
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.27802690
I'm assuming from your problem that the washer went through its' first wash cycle, drained and spun, then filled again for the rinse cycle, went through the rinse and didn't go to the drain / spin cycle.
If that is correct, it appears that the motor, pump and transmission are working. It also appears that the Lid Switch is working. These are the main places to look for a problem such as yours.
If you stop the washer by pushing the control knob in, moving it to the spin cycle and starting it again, and the washer still doesn't spin, the problem points to a defective timer.
Before replacing the timer, I'd check the Lid Switch again by removing the two Trim End Caps and the two screws under them. Tilt the console back and disconnect the connector from the console to the lid switch.
Using a short insulated wire, jumper the Lid Switch at the console by jumping between the two outer pins.
Following is the Whirlpool Installation and Maintenance manual for these machines with a section on how to jumper the switch.
Then try to start the machine in the spin mode.
If it works, the problem is in the Lid Switch.
If not, It is likely in the timer.
Posted on Sep 30, 2009
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
Won't turn on
usually a tripped fuse inside the diswasher that stops power to the controller.
Will need full model number to make any further assessment.
Jan 04, 2013 | Maytag Dishwashers
Washer stopped during rinse cycle.
If possible, you can drop the hose to floor level and gravity will drain the water. You may need a hose extension. The other option is to pan the water out. What is the model number of your unit?
Oct 15, 2012 | Estate Washing Machines
When i turn the key on i have no turn signals,radio won't play right. with the key in the start position the engine won't turn over. four way flashers have also stopped working. have replaced...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:1
Aug 12, 2011 | 1990 Chevrolet K1500
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
Front fuel tank not responding
based on my 20 years in a Ford dealer your problem is the front pump.
May 21, 2009 | 1989 Ford Econoline
Kenmore washer stopped full of water, will not click etc
possible bad lid switch..if switch cks ok ck for wiring connection on motor
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
123 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
