Question about Festool CT22e Vacuum
Where can I get a wiring diagram for this machine? Switch seems to be bad.
Wiring diagram
The only place I know of fora wiring diagram for a Guardian is at the local branch office. The new name for the Electrolux is now AERUS.
Check your phone book.
There is a fuse wire that runs from the cordwinder to the triac circuit board inside the vacuum canister. You have to take the six screws out of the bottom. Open the bag door and lift up on the top handle to remove the top part.
It is vere advisable to take your vacuum to the branch office that has a qualified service manager. You can do more harm than good on the inside of the machine.
Jul 22, 2014 | Electrolux Guardian Bagged Canister Vacuum
Wiring diagram
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Jul 24, 2008 | Miele Cat & Dog 326i Bagged Canister...
I need the wiring diagram for a Mighty Pro x3 Wide Track carpet cleaniung machine
Request the wiring diagram directly from Mighty Pro.
Jan 03, 2018 | Vacuums
My oreck upright model xl3640 is not turning on. A clothespin was accidently vacuumed up, and the machine was immediately turned off to remove it. The bottom panel of the machine was taken off to remove...
the Oreck XL3640 power switch goes bad most vacuum service center can order a new switch it has 3 wires remove screws from handle to get at switch hook up wires to new switch color code of wires of wires are black white black just put on right terminal on switch _1284.jpg
Mar 08, 2011 | Vacuums
Explain how to re-wire 16gal craftsman shopvac,switch wires are- 2 orange wires, one white, one black and one green(grd wire), I pulled them off and don't where each wire goes.
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
I hope this helps you
If I have misunderstood your question, please ask again.
a
Oct 05, 2009 | Vacuums
Vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
http://kirby-owners-club-shop.com/faqs.htm
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
Gary
May 24, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Aug 31, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Festool CT22e Vacuum Logo
61 people viewed this question
Top Festool Vacuums Experts
JoeVacs
Are you a Festool Vacuum Expert? Answer questions, earn points and help others
