Question about Dell Inspiron 1520 Motherboard
Dell Inspiron 1520 will not start
My Dell Inspiron 1520 will not start I have checked out the modual under the cover but it still won't start, no lights at all. When I plug in the power supply the green light on it goes out which does not sound to good. The pc stopped working all of a suden it and just went dead.Typicaly it was a month out of warranty and it is no longer covered.
  • 3 Answers
SOURCE: dead - no response
Hi, I am looking for a battery related problem solution on my own Axim X51v, but it is different than yours. One thing I wanted to share with you is that I know if the battery cover lock button is not in the locked position (slid to the right) it activates the "battery door switch". I have occasionally received error messages on the Axim when I turn the screen on and it has missed sounding an alarm. it will say "the battery door switch was open, so the system was put into "sleep mode" to preserve data from being lost" or something like that. So I believe that the position of the latch is crucial. In my case, I think the switch gets dirty. When I get the warning, I slide the switch back and forth a few times and then it stops bugging me for sometimes several months.
So, if you do not have the cover on, then your latch is probably open, and the door switch will be sensed as open. I am not sure what Sleep Mode really does, but I'll bet it will make the Axim appear dead. At the very least, try sliding that latch back to the right. However, I would replace the door, because only friction actually holds the battery in place unless the door is on. It could fall out when you least expect it. Then I think you would lose any unsaved data, and if your internal backup battery was not up to the task, you could lose everything. I hope this info helps you out.
I'll go post my own problem now.
Posted on Oct 27, 2007
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 145 Answers
SOURCE: Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Posted on Oct 16, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I have a dell inspiron 1520. I have had to set my laptop up on a seperate mmonitor as my screen doesn't work properly. If my screen lights up it may last 5 mins before going dark you can see the screen...
At the base of the screen there is a long bulb, looks like a florescent bulb from a scanner, that is connected to a small board just under the to cover near the the monitor itself. You need to replace that small board. You can get it on Ebay or from Dell. Remove the board to get the part number.
Jun 18, 2010 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
May 13, 2010 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power light is on for few seconds, then nothing happens, is this a factory defect?
have you tried chsrging it up by plugging in for a long period, make sure the cable to the transformer is actually plugged in securely they tend to work loose and look okay but arent.
Mar 21, 2010 | Dell Inspiron 1520 Motherboard
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
I have the same problem with my dell inspiron 1520 laptop
You have an obvious electrical problem. It could be that the switch on the power module is faulty.
Remove the hinge cover and depress the power switch on the power module. If the system is starting without hinderance then the issue is the tab under the hinge cover is not making proper connection with the switch below. If the same problems persist when you go directly to the power module then the module has a faulty switch. Radio shack has those tact switches for $3.58. You can either replace the switch or replace the module.
Good Luck
Sep 27, 2009 | Dell Inspiron 1520 Motherboard
Solution for ''the power light for dell inspiron 1520 turns on for about 5 seconds and goes out
If there is a yellow light on the front panel, indicates a faulty AC adapter. If you know someone with an Inspiron 1520, test with their adapter.
Jun 13, 2009 | Dell Computers & Internet
The screen is blank but I can see a faint image.
Try reseating the cable that goes to the back of the lcd and also the other end of that cable that plugs into the motherboard. If that doesn't do it then either the lcd or the inverter is bad. Either way when you get a replacement screen for a dell laptop it normally comes with a new inverter as well. If your laptop is under warranty thru dell then you can get it replaced thru them. If you have your serial number then I can look it up and see if your system is still under warranty.
May 26, 2009 | Dell 0JM629 Inspiron 1520 Keyboard
Dell Inspiron 1520  Motherboard Logo
545 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
