Question about Sony BRAVIA KDL-32V2000 32 in. LCD Television
I have a Sony Bravia KDL-32V2000 and cannot re tune channel 5 digital programme. I am trying to follow the instructions printed in the Daily Mail but when I press Menu it does not take me to 'set uo' or 'instLLATION'.
3 Suggested Answers
  • 65 Answers
SOURCE: kdl-32v2000 sony bravia self diagnostic 4 flashes
Sounds like bad inverter boards.
Posted on Mar 22, 2010
dcramer531
  • 1654 Answers
SOURCE: Bravia KDL 32V2000 .Froze when
There is a tiny component in the digital tuner that may be the cause of your issue. That component is a surface mount fuse. Unless you are very confident with your soldering abilities you need to take your set to your nearest Sony authorised service centre for repair. Sony uses a "board level repair" policy for the digital tuners in their sets so there is no service information available for that part of the TV - meaning that if the service centre you take the set to want to change the whole board then that is because that is Sony's policy and that they are possibly not aware of the root cause of the failure being a 50c part. This fuse is very tiny and not an easy solder if your unexperienced but it can be replaced. There is also the option of using an external HD digital tuner. Not sure how old this set is but they have a hidden extended warranty period of between 1 and 3 months ONTOP of the current warranty for this issue. On the digital Tuner board there is an "F1" and an "F2" (very small fuses) on the circuit board. I don't recomend this but if you would solder across the fuse to complete the circuit you set will again pick up the digital signals but you wont have a fuse. If your hand and can solder a replacement fuse across the board that will fix the issue as well. I use a sat reciever box or you can use the cable box as an external tuner as well. This repair done by Sony will run around $600.00 for the newer digital tuner board.
Posted on Aug 04, 2011
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
How do I tune in channels on this TV
if you hook to cable. first you need to go program ang scan the autoscan first in order to change the channel.
May 09, 2010 | Sony BRAVIA KDL-32V2000 32 in. LCD...
Sony Bravia KDL-32V2000 LCD TV switching off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 29, 2017 | Sony Televison & Video
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
SONY BRAVIA -KDF-E50A12U- SENTANTA FREEVIEW TUNING PROBLEMS.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Aug 13, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KDL-20s2030
redo The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
May 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Loss of freeview channels
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Feb 08, 2008 | Sony KDL-26U2000 26 in. LCD Television
Sony BRAVIA KDL-32V2000 32 in. LCD Television Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
