Question about Proform CrossTrainer Treadmill
My Proform treadmill comes on but won't start
I hadn't used my treadmill for about a month. I got it out and it lights up, it will change programs but the speed and incline buttons seem "dead". I adjusted the reed switch, I also took off the operator panel but nothing looks out of place. No change. Please help, this treadmill isn't very old and it's one of the more expensive models from Sears.
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
bunnydawg
  • 5158 Answers
SOURCE: I have a sears proform 585 treadmill.
if it is a plastic belt do not put any oil near it as that degrades it
Posted on Jan 23, 2009
  • 16 Answers
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Posted on Apr 14, 2009
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Proform 615 xp won't come down from folding it
I am having the exact same problem with my ProForm 615 treadmill. Spent over an hour trying to lower it.
Jun 23, 2012 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
I have a Proform 545s treadmill with incline and with ifit. When i start the treadmill it will no longer attain the programed speed. The higher the speed programed the fast the treadmill will go; however,...
It sounds a lot like it might be your Motor Control Board. You can find one used on varios websites (ebay if you're lucky). I found one for $149.00 on the following website:
http://www.treadmilldoctor.com/PROFORM-545S-TREADMILL-Motor-Control-Board
I hope you got a good deal on it because it seems to be quite an expensive part.
Thanks and good luck!
Mar 21, 2011 | Proform Exercise & Fitness
I have a Proform 590T treadmill that is 3 months old - about 60 - 75 miles on it and it has become noisy. Not a clunking just a loud hum. It is the same noise regardless if you are walking on it or just...
It might be motor bearings or a roller. Remove the drive belt and run the machine.
Icon has a good warranty program. I am a service tech for the company working in Canada. If it is only 3 months old, call ICON and arrange a service call from a qualified tech.
1-888-533-1333.
Dec 14, 2010 | Proform 590T Treadmill
I have a proform lx660 treadmill. it has been
Open the cover from the main motor.
See if the drive belt is o.k ? or is loose or is Bad?
If the drive belt is o.k You must sure, the Feed wires for the motor are very tight from the terminal Control Board Motor, and then use Electronic Cleaner Contact for the Control board Motor. This cleaner make a good job, for cleaning the corrosion, dust or other situation in the board.
If ater cleaning the board , the problem persist, Take out the Brush in the main motor and see if there are o.k-cleaned? or Wear.
Looke for some wires loose in the control board motor, and tight very well. Most of the main motor has thermal switch inside look if the wires are loose? Tight it.
How to Change the Time on Fitbit LED Blink Patterns on the Control Board Treadmill
Dec 15, 2017 | Proform Exercise & Fitness
E-21
start /variable sp. sw. needs replacement.
easy fix for most electric appliance repair person
Jan 07, 2009 | Proform 575 Crosstrainer Treadmill
Proform CrossTrainer Treadmill Logo
5,567 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
