Question about RCA HD52W59 HDTV Projection Television
My RCA52W59 wont turn on. I plug it in and the
My RCA52W59 wont turn on. I plug it in and the power light turns on without even being pressed. Then it flickers but no picture appears and no sound. When I try to turn off the power the light on the power button stays on. I can hear the tv power on when I plug it in and when I press the power button but nothing happens. Also I can sometimes hear it repeatedly make a power on noise without me doing anything as if it is turning itself on and off before the picture gets a chance to appear or something.
  • 647 Answers
Common faults with this model are flyback trans former and power supply problems (capacitors)
This set is in shut down or protection mode and will attempt to restart 3 times
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Posted on Sep 30, 2009
My sony vaio PGC-3E2L wont turn on, not even when i plug the charger. The only thing it does is turn on the battery and power lights only when i press the power button but turn off when i release it
Take out the battery and try with just the charger, Batteries for computers have regulators in them and when the batteries die, the computer wont boot.
Dec 08, 2016 | Sony Computers & Internet
87virago1100cc wont kick over seems like a relay or switch cause it wont even click
Do any lights come on when the key is turned? Are you you sure there is power from the battery? If yes then what happens when the start button is pressed? Do the lights dim at all? Even without a click noise if the button is supplying power to the solinoid the oil check/dummy lights should dim slightly. If no dimming but the lights are on when the key is turned, start by checking the starter button, if there is no power there trace your way back to the battery with a voltmeter until you find where the power stops.
Mar 23, 2012 | 1999 Yamaha XVS 1100 Dragstar
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
I tried to restore factory settings on my Toshiba Saetellite L500D and it will not configure. Kept trying to configure - got to first screen where it asks you to press enter to commence system set up and...
Try to do a complete power drain by doing the following:
1.Remove the power cable.
2.Remove the battery.
3.Press and hold the power button for at least 10-15 sec to drain all remaining power stored in the board.
After this, try plugging the power cable without the battery and turn on the computer. Check if the computer will respond. Put the battery back.
Nov 12, 2010 | Toshiba Computers & Internet
Laptop will not turn on when i press the on
Normally, if the LCDs light momentarily and go off, then the system is not getting power from the AC adapter (Even if the light is on on the brick)
  1. If another Dell D-Series AC adapter is available, try it. if not check the output for the plug to the system for 19 volts DC, if no voltage, replace the adapter.
  2. Check the connection on the system for cracks or loose connection to the motherboard. If the connector is damaged, then the jack or the motherboard will need replacement
  3. If the system will not power on with a known good battery or AC adapter, then try these steps.
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Dec 25, 2009 | Computers & Internet
My garmin sat nuv wont turn on even after pressing
plug it in to the house or car charger for at least 4 hours, then try again. if it still wont turn on, we can try something else.
bill
Aug 31, 2009 | GPS
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
Ps2 slim console wont turn on!
i checked the manual (troubleshooting) 1. turn off PS2 2. unplug it then, plug it back in and turn it on(andprayitstillworks).
Jan 10, 2009 | Sony PlayStation 2 (PS2) Console
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
RCA HD52W59 HDTV Projection Television Logo
217 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
