Question about Mitsubishi CK-35308 35" TV
Sound takes up to an hour to come on, Mitsubishi 35'' tv
35'' mitsubishi tv, about 10 years old, picture is great, but sound takes up to an hour to finally come on, used to take about ten minutes after warm up to get sound; we had a lightning storm not too long ago, could that have made the problem worse? Checked the cables, settings, etc, all seems fine. Was told it was a sound board and they could fix it for $700.00, I could buy a new tv for less than that. Any suggestions?
  • 647 Answers
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Posted on Sep 30, 2009
My mitsubishi tv is almost 3 years old and it has no picture but it has sound
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Mar 31, 2013 | Mitsubishi WD-62526 Projection TV
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
No picture
Symptoms shows TV got problem in Horizontal deflection area that's why you do not see picture and get only sound.I think its not worth to repair as its 14 years old model and spear parts might not be available or cost too much. Since you still want to repair it, let me know exact model number of TV to check parts are available some where?
Jan 10, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
Mitsubishi CS-35805 TV
Sorry to be the one to inform you Sheri, but this set is known to have several bad capacitors in the sweep as well as the power supply. Unless you have an ESR type capacitor checker, your going to have to take it in for service, by a pro. Hope yopu did'nt pay to much for it. Good Luck
Jul 24, 2006 | Mitsubishi CS-35805 35" TV
Televison & Video Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
