Question about Dacor Kitchen Ranges
I have a Dacor SGG365 Gas cooktop with an RV368 fan/vent that rises in the back at the touch of the button. The fan will no longer rise in the back and there seems to be a slight odor or an electrical kind when I press the button.
  • 958 Answers
SOURCE: We have a separate Jenn-Air
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
SOURCE: cooktop wont unlock
Press and hold the "Top" button for five seconds. It worked.
Posted on Oct 27, 2008
  • 3 Answers
SOURCE: Raised vent is Rising after being lowered
My RV30S was installed by a qualified service technician in approximately the year 2000. It finally developed a mind of its own. It would raise up and run for a bit and then stop....sometimes it wouldn't raise up or go down....it would switch from fast to slow to stop.....it became frustratingly unusable....
...today i finally took it upon myself to take it apart and I determined that the controller board had fried.
Before I go on -> Disclaimer: These units are hard-wired to live A.C. power. These units must be serviced by technically qualified service personnel. I do NOT recommend anyone to attempt this service. I've worked in the past as an electrical engineer by trade. But to save you time and money you can shop and buy the parts you need yourself and then hire an appliance service technician to safely install them for you. This way they can't rip you off by over charging for the parts and you can certainly count the hours for the install.
The controller board is shown here. In my case, this diode fried.
I found a replacement controller on E-Bay for only $82 bucks and change. At the time of this writing they had 14 in stock.
http://cgi.ebay.com/NEW-Dacor-Vent-Hood-Control-Board-DA-72881_W0QQitemZ120363680495QQcmdZViewItemQQptZRanges_Cooking_Appliances?hash=item120363680495&_trksid=p3286.m20.l1116
It sounds like you may be having the same problem. But please be sure to hire a qualified appliance service technician to do the work. If he quotes a price for the controller board anything over 82 bucks, you will indeed will be in a better position to negotiate a better deal.
Hope this helps anyone that is having or will have the same problem with an older RV30....
Posted on Mar 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
  • 2976 Answers
SOURCE: Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
Posted on May 08, 2009
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Vent does not rise to clean air
come again boss, i don't get what you mean?
Feb 16, 2011 | Dacor Preference SGM466 Gas Cooktop
I have a Viking cooktop with a fan that rises when the side button is pushed. The fan will no longer go up. How can I fix it?
I just finished researching the same issue for my 36" downdraft. It appears that the ost common problem is the little up/down switch.
Most folks on-line were being told that they had to buy the whole top unit for $500.00 plus labor. But an electrical engineerpointed out that allvikingparts.com sold a switch for about $60.00 delivered.
It seems that if one holds the switch for an extended period of time it can heat up and burn a connector - might be a coincidence, but my unit stopped working just after my 4 year old grandson visited for two weeks - I made the mistake of showing him how pushing the button would make the vent go up and down. So the switch probably got mre use in a week than it had in the eight years since it was installed.
You can simply peel your switch off with your finger nail ( it will stick right back). On mine I noticed that the center "wire" hade a dark line through it which probably indicates that it is "burned"
My part is on the way.
Hope this helps - $57.00 is much easier to swallow than $595.00
May 20, 2010 | Viking 31 in. VGSU101 Gas Cooktop
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Oct 22, 2008 | Cooktops
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Dacor downdraft vent
YOU WILL NEED TO CONTACT A AUTHORIZED DACOR DEALER OR PARTS DISTRIBUTOR I SUGGEST CALLING FOX APPLIANCE IN ATLANTA GA OR THE MFG IN BERKLEY ,CA
May 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
297 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
