Question about Ridgid Vacuums
Vac will not pick up water - Ridgid Vacuums
  • 4 Answers
I have a shop Vac too. It will only pick up when held at the surface rather than completely submerged.
Posted on Sep 30, 2009
I have a wet/vac model 2010a 1..0 peak hp do i put the gray filter on to sick up water or to dry vac
The filter is only for dry use. When you are picking up water etc with it, don't use any filters. They get ruined.
Apr 02, 2017 | Filter Vacuums
I can't find the owner's manual to our shop vac. What's involved in converting it from a dry vac to a wet vac? I think it does both, but I've only ever used it to clean the car.
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Jul 23, 2011 | Shop Vac 5841627 Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
What if i use my wet dry vac to pick up water without a filter
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
112 people viewed this question
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
superjulimaximo
superjulimaximo
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
