Question about Car Audio & Video
I have two cd stucked in my stero .and i can't play my cd player
  • 4,862 Answers
You can either try to tease them out using an old CD through the slot .....or the player will have to be removed from the dashboard , the covers taken off and the  CDs taken out.
Make sure you have the SECURITY CODE before you start.
If you do not have the code then POST ANOTHER QUESTION
quoting the radio/player  MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
Here is a useful website showing how to remove your radio from the dashboard.
http://www.fitaudio.com/
Posted on Sep 30, 2009
Why did my Denon Carousel CD player stop working and can it be fixed?
I'm not sure if this will help, but when that happened to my CD player the solution was very simple. I removed the outter cover and took a Q-tip dampened with some alcohol and cleaned the little lens that reads the cd. It's a very common problem, and the fact that yours is 15 years old guarentees the lens is dirty. Some people trash their stero when It could've been good as new with just a Q-tip & little alcohol.
I hope it works!
Laura
Mar 05, 2015 | Denon Audio Players & Recorders
Factory stero
You will need to remove the CD player from the dash and then take it apart to retrieve the CD, then get it repaired the loading mechanism is defective.
Feb 14, 2012 | 2005 Pontiac Grand Prix
My cd steroe system keeps showing no play when i try to play a cd
their is a fault with the mechanism and it will cost more to repair than its worth just buy a new player unless you know a friendly repair man in panasonic
Dec 25, 2011 | Panasonic Audio Players & Recorders
Cd is stuck in car stero how do I get it out
Hold the SELECT button and the powere button together for a few seconds, this should reset the player. You will lose any radio presets, but the cd will be ejected.
Nov 01, 2009 | JVC KD-S5050 CD Player
Cd stuck in factory stero
You Will Need To Unhook Your Battery From The Car And This Should Reset The Cd Player And Should Reject It
Jun 13, 2009 | Car Audio & Video
AKAI CD-M600 CD PLAYER not working.
Akai CD player playing very S L O W L Y and the CD door won't open and if it does, it goes into ewject mode. Help!!! Has an internal motor died??? Can i be repaired???
Mar 29, 2009 | Audio Players & Recorders
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Feb 24, 2009 | Car Audio & Video
Electrical problems with the a/c and stero control lights
Check charging system..may have a bad alternator. good
luck
Dec 19, 2008 | 2004 Infiniti G35 Sport Coupe
When put in stero mode,the speakers blast out at full volume..
I had the same problem and have solved it bij resetting it.
Try the small hole above the powerswitch.
Good luck.
Oct 30, 2008 | Cambridge Audio Azur 540R Receiver
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
