Question about Maytag 30" Self-Cleaning Freestanding Electric Range - Bisque
Hoow do I remove the top froma maytag range?
How do I remove the top froma maytag range? i need to replace two burner elements.
  • Anonymous Mar 20, 2014
    top is hinged and can not be removed
    President:
  • 1,304 Answers
There should be two small screws on the corners thay are black so you really gotta look
once removed your top should flip up
Posted on Oct 03, 2009
Where can I go and get directions on how to replace the front left element on my glass top Maytag stove model #mer5750BAW. The stove top has to be lifted and the element underneth needs to be replaced or...
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
Jan 15, 2010 | Maytag MER5750 Electric Kitchen Range
Back burner doesn't work looking to remove and
These burners are very simple to replace. Is yours a glass top or does it have coil elements on the top of your stove?
Either way, we can direct and guide you to complete this repair.
You will need to contact us with your model number and we can tell you exactly how to remove and replace the element. When you get your parts from us, here at Accurate Appliance & Parts Supplies, we send complete instructions when when we send the parts to you.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday.
We hope to get you cooking again soon and look forward to working with you. Thanks, Ella
Nov 21, 2009 | Maytag Gemini 30" Self-Cleaning...
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
Replaced bake element but will not heat
I had the same thing happen to me replaced burner did not fix the problem so I ended up calling service guy and it ended up being a lose connection on the mother board all he had to do is solder the wire!!
Jul 10, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Dec 21, 2007 | Kitchen Ranges
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Burners not working on a Maytag Electric Range
The top of the range will open if you remove the three screws under the front edge of the top. You will need to open the oven door to see them. But first, unplug the range or turn of the circuit breaker. There's still live voltages (240VAC) even with the range turned off. Also use care not to lean on the oven door or you could damage the springs. If the top does not have any brackets to hold it up you may need to find something to prop it up, or use a second set of hands. The elements are easily removed by removing a couple of screws and the some wires. Write down the wire colors and where they go to assist in making sure you reconnect them correctly. Also, pay particular attention to the numbered holes on the back of the element. Make sure you reconnect the retaining brackets in the same numbered holes as you removed them. Last of all, do not handle the ceramic material or element coil with your bare hands. They are fragile and the oils from your hands could create hot spots and potentially ruin the element. I do not know the arrangement of your elements, but I suspect you have one of each size burned out. The part numbers are as follows: 6" element: 1032743 9" element: 1035285 The prices are about the same ($40 ea.) with the larger element costing slightly more. I hope this helps you.
Sep 02, 2007 | Maytag MER5750 Electric Kitchen Range
Maytag 30" Self-Cleaning Freestanding Electric Range - Bisque Logo
245 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
