Question about Nikon D90 Digital Camera with 18-105mm lens
Flashing F. shutter locked. - Nikon D90 Digital Camera with 18-105mm lens
It has a flashing E, it will not take pictures, the lens does not retract any ideas please?
Flashing E error Mean Lens Error.
Either shutter lens is damage due to weak magnets in the Coil which activate the shutter lens blinking function.
Mar 19, 2015 | FUJIFILM Instax 200 Film Camera
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
Jan 27, 2014 | Pentax K1000 35mm SLR Camera
Camera flashing red light and refuses to come up
the shutter assembly might be stuck or broken, just give it some hard knocking not to break but just unfreeze the shutter leaf
Dec 09, 2013 | Canon PowerShot A3000 IS Digital Camera
Shutter button wont go down on my N2020 nikon
Make sure the shutter isn't locked. Lift the ring around the shutter button and turn it to something other than the "L" for lock position.
If you need a manual, you may download a copy from here.
Nov 24, 2012 | Nikon N2020 35mm SLR Camera
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
My Praktica LLC mirror locks up and won't return. The shutter stays open partly or fully.
do you have exact model - this maybe bulb which allows the shutter to stay open for as long as the shutter release is pressed - or mirror lock setting - for macro work to avoid any camera shake when the mirror moves - by locking the mirror
Mar 30, 2010 | Photography
A700 flashing "lens" message
Is the lens switched to manual as well as the mode dial. If the compatable lens is a minolta requiring an M42 adapter make sure that the protruding arm/rod is operating the shutter when depressed and that the adapter when fitted operates the lens when turned from auto to manual. Good luck.
Jun 27, 2009 | Sony Alpha DSLR-A700
My Nikon D50 locks up intermittently
you like to try and swapping batteries.. i guess it couldnt supply enought power to the shutter motor.
Aug 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
