Question about Sharp AR-M237 Copier
Sharp AR-M237 Grayscale Copier Problem
When printing word documents with grayscale images or colour images (.jpg) they do not print clear, yet when same files are printed on a low end ink jet they print just fine. Is there a setting somewhere in the software for printing grayscale images?
  • 208 Answers
Yes.There should be settings to enhance that in your print driver properties page.
Easiest way to access that is to open a document and click "file' then 'print and that will bring up your printer options.
Look around the print driver for ways to enhance your prints.
Most drivers have several options in graphics areas to make adjustments.
You can access printers from the controle panel and also right click the printer and select properties to access it.
There definatly are ways to adjust that.
Hope this helps you some.
Posted on Dec 20, 2007
Selecting Grayscale and then Default isn't working. The printer reverts to auto colour after the first Grayscale print operation. How do I make Grayscale operate automatically each time please?
Setting default on the printer copier can be over written by the software. each document/letter/spread sheet etc has print properties associated with it. when you tell it to print without going to the properties area it will print like the last time you printed and override any settings on the actual hardware. Software always has the ability to override the hardware in any brand.If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
Apr 08, 2016 | Office Equipment & Supplies
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
Mar 19, 2011 | Sharp AR-M237 Copier
I use my Sharp AR-BC320 as a network printer, how do I set the print mode to default black & white. It is currently set to always print color. I have searched the manual and is says nothing about print...
On the Print Window.
1. Click on the Properties button.
2. Click the Color Tab and Choose the "Print in Grayscale" option and Select "Black ink only"
3. Click the Printing Shortcuts Tab. Click the "Save As" button and assign a shortcut name you can remember.
4. Then click "OK". and print.
5. The next time you print a document just look for that in the printing shortcuts.
Mar 18, 2011 | Sharp AR-BC320 All-In-One Led Printer
Transaction Report that includes portion of the fax in AR-5127, not only in error - is it possible?
In fax mode, touch the [SPECIAL MODES]
If you want the transaction report to print regardless
of whether the transmission succeeds or fails, touch
the [ALWAYS PRINT] key.
Touch the outer [OK] key.
Oct 20, 2010 | Sharp AR-M237 Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
All copies from the glass or file print with dot with grayscale
you need your developer replaced. That will solve the gray blacks/
Jan 14, 2009 | Sharp AR-M700N Copier
RE:Cannot print in documents
It's one of two problems, either the nozzles in the cartridge are clogged or your printing preferences are set to "print in grayscale." To clear the nozzles try running the printer through a "deep cleaning" cycle from the printer's maintenance screen (available from the printer's properties). To check the printing preferences go to the printer's properties, as well, from Start > Control Panel > Printers & Faxes > right-click on the printer and choose Printing Preferences. Make sure to uncheck "Print In Grayscale."
Nov 11, 2007 | Compaq Inkjet IJ650 Printer
Sharp AR-M237 Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
