Question about IBM ThinkPad X31 Notebook
Can't remove x31 from docking station
The release lever is loose. The front end of the laptop is loose, but the rear is firmly attached. Don't want to force it or may damage the laptop. Anyone have a solution?
Remove x31 dock by pulling leaver fully forward-- lift back of laptop APP.1 CM and slide back. SWITCH OFF FIRST 'J'
Posted on Apr 08, 2011
    Brigadier General:
  • 10,406 Answers
You asked this question a year ago, and did not get any help.
So, it's time to take a chain-saw to the docking-station, to "sacrifice" it,
and then purchase (on eBay?) a replacement docking-station.
Posted on Jan 30, 2011
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Where is docking station release lever on ThinkPad X31 (P/N 91P9024)? Please advise.
should be top right corner. push down.
make sure the key is not in lock position.
Jun 12, 2011 | IBM Computers & Internet
Cant remove ibm thinkpad x31 from docking station
Press the "release" button/lever, to allow the ThinkPad to be "unlocked" and released from the docking station.
Jan 27, 2011 | IBM ThinkPad X31 Notebook
How do I undock the X 200 from the ultra base?
There is a keyed lock on the right hand side to the rear of the base. Once this is unlocked, pull the release lever out and towards the front. The release lever is on the left side of the base towards the front. This will release the laptop from the base which one should then lift directly up to separate the two components.
Jan 18, 2011 | Lenovo ThinkPad X200 Notebook
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
Loose emergency brake on 2004 Saturn Vue
  1. Apply and fully release the park brake several times. Verify that the park brake lever releases completely.
  2. Turn ON the ignition. Verify the red BRAKE warning lamp is not illuminated.
  3. If the red BRAKE warning lamp is illuminated, verify the following:
    • The park brake lever is in the fully released position and against the stop.
    • There is no slack in the park brake cable.
  1. Turn OFF the ignition.
  2. Disable the SIR system.
  3. Remove the front floor console.
  4. With the park brake lever in the released position, using ONLY hand tools, loosen the adjusting nut completely to the end of the front cable threaded rod.
  5. Raise and support the vehicle.
  6. Remove the rear tire and wheel assemblies.
  7. Adjust the rear drum brakes.
  8. Ensure there is no brake shoe drag after adjustment by rotating the brake drums. If drag exists, re-center the brake shoes and perform the brake shoe adjustment again.
  9. Install 2 wheel nuts to the wheel studs and firmly hand tighten in order to retain the brake drums.
  10. Lower the vehicle to permit access to the park brake lever.
  11. Raise the park brake lever 1 detent position. Notice: Refer to Fastener Notice in Service Precautions.
Jan 14, 2009 | 2004 Saturn VUE
Removing laptop from docking station
If you have the ArmadaStation EM:
The issue of removing the notebook is compounded by the fact that the ArmadaStation EM uses a motorized dock/undock mechanism to remove the notebook. When the expansion base has no power, it is unable to eject the notebook with the motor
 To manually remove the notebook, use manual eject lever to push notebook out of ArmadaStation EM. The manual eject level is a small white lever located inside the back cover of the base. To remove the notebook, push the white lever to the left. Slight pulling is required to remove the notebook completely out of the base.
Hope this helps!
Jan 15, 2008 | Computers & Internet
IBM ThinkPad X31 Notebook Logo
306 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
