Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Loss of electricity due to the ice storm...
Well, I was out of electricity for 9 days and it dropped below 40 degrees in the house. Once the power was back on and the house was warm, I tuned on the TV and the color is horrable. I tried adjusting the color menu, but it didn't help at all.
I need to know if the power outage is the cause of the problem so I can claim it on my insurance. Also, what it will take to get this fixed (if anything).
Thanks,
Bobby
    President:
  • 4,402 Answers
If it worked before and not after i would claim it, also sometimes if you complain to the electric company they will foot the bill on there insurance. power surge can cause all sorts of problems . just my 2 cents.
now this set is also know to have bad convergance ic
check this site out for repairing it.
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
By manual convergence, if you mean electrostatic convergence, then I'm not sure this is included in the service manual. However, if you join the http://groups.yahoo.com/sonyhdtv/ group, there is a file download called ws500tweaks.doc that documents this (with the usual caveats, like don't get yourself killed, when in doubt hire a pro, etc).
Posted on Dec 19, 2007
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Jan 06, 2015 | Heating & Cooling
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
2008 Kawasaki Vulcan 1600 Nomad high-speed power loss
Hi, Anonymous and the usual suspects are:
1. Dirty or clogged air filter.
2. Faulty spark plug.
3. Bad Gas.
4. Improper oil level.
5. Improper chain adjustment and lubrication.
6. Low tire pressure.
7. Dirty or contaminated carburetor needs cleaning and tuning.
8. Clogged or faulty fuel pump or injectors.
9. Improper valve adjustment.
10. Slipping clutch.
11. Improper timing.
12. Low compression.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Loss of Power not related to Electrics Kawasaki Vulcan Forum Vulcan Forums
Loss of power Vulcan Bagger Forums
Kawasaki VULCAN 1600 NOMAD Service Manual
OEM Parts for Kawasaki
2008 Kawasaki Vulcan 1600 Classic Owner Manual
Feb 08, 2012 | 2008 kawasaki Vulcan 1600 Nomad
My 2005 Saturn ION (4 cylinders) won't start. With the ignition key turned, I get multiple clicks. I can get radio and dashboard lights until I try to roll down a power window. Then every shuts down. I...
If the starter cranks but the engine won't start, there could be wide range of problems. Here are some of the most common:
- Problems with fuel delivery system (e.g bad fuel pump, fuel pump relay, clogged fuel screen, etc.)
- Problem with engine electronics (e.g crank sensor, cam sensor, air flow sensor, power relay, engine computer, etc.)
- Ignition system problems, especially on older vehicles with the distributor (e.g bad ignition coil, commutator, rotor, distributor cap, etc.)
- Defective ignition switch
- Problems with vehicle security system
- Internal engine problems (e.g broken timing belt or gear, low compression, etc.)
Make sure that you have fuel in the tank. It may be that your vehicle fuel gauge isn't working properly.The first signs that there is too little fuel in the tank are occasional lugging, loss of power, and a louder, irregular sound of the electric fuel pump coming out from the fuel tank
Jan 01, 2011 | 2005 Saturn ION
Ist ik for capacitors to be expose on heat inside my room when i am out because all the windows are close? the heat is about 40 to 45 degrees celcious.
Most capacitors are designed to have an effective heat usage range before they start to change capacitance values. They will normally run in an environment of below 32F to 120F without any variation in the capacitence rating of the capacitor. Beyond these points the capacity may start changing.
Apr 13, 2009 | Car Audio & Video
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
